Question about HP Office Equipment & Supplies
Error code 59.0C in hp color laserjet 3600 printer
SOURCE: HP Color Lserjet 3600
We found that we had a defective cartridge. We returned it. A replacement cartridge did not cause the printer to callibrate continuously.
Posted on Mar 26, 2009
iron_luiggi
  • 91 Answers
SOURCE: HP LaserJet Color 3600
you should try the SOLLUTION 5
This is an answer to most of the problems of "continuous calibration" in the HP 3600.
When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://translate.google.com/translate?js=y&prev=_t&hl=es&ie=UTF-8&layout=1&eotf=1&u=http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-the-printer-hp-3600n-to-edit-print-defective / & sl = en & tl = en
Posted on Apr 15, 2010
SOURCE: error 51.23 on HP 3600 color laserjet printer
Error 51.23 on HP 3600 color laserjet printer
Posted on Dec 25, 2008
sys_admin
  • 829 Answers
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Posted on Mar 22, 2009
  • 4 Answers
SOURCE: My ph laserjet color printer 4650dn is showing
There is a fix for this issue @ http://www.fixyourownprinter.com/forums/printer/30528
Posted on Nov 04, 2009
HP jet printer 3600 displays error 54.17
Non HP cartridges is not the issue. Maybe you have a defective cartridge. The error is caused by changing the cartridges so you have a clue now. Which cartridge you changed that produced that error, you need to replace that cartridge.
Mar 26, 2013 | HP LaserJet 3600 Printer
My printer HP Color laserjet4050 has a error 49.234A if i print status pages it came blank
A laserjet 4050 is NOT color.
Normally the 49.xx.xx errors are firmware errors.
Go out to www.hp.com and download the latest firmware.
Follow the directions and install it.
Jun 27, 2011 | Office Equipment & Supplies
Problem Error Code 59.FO For HP Color LaserJet 3600 Printer
If you haven't taken your printer apart, somehow the "cams" in the developer drive assembly worked their way out of alignment.
Somebody trained is going to have to align and calibrate the main drive assembly.
Mar 04, 2011 | HP LaserJet 3600n Printer
Problem Error Code 54.OC.01 For HP Color LaserJet 3600 Printer
If the error won't go away, the DC Controller in the printer will have to be replaced.
The ".0C.01" part of the error can't be found in the service manual, but I don't think that it will change the fix.
No writing on the right side of the sheet with black and color faded out on same side with color
if i read this correctly both color and black are missing from one side?
this is most likely a problem with the belt.
if it was just 1 color or black it would be that toner/drum cartridge or the laser associated with it.
http://www.precisionroller.com/belts-for-hp-color-laserjet-3600/details_45933.html
for non duplex
and
http://www.precisionroller.com/belts-for-hp-color-laserjet-3600/details_45935.html
for duplex model
Jan 19, 2011 | HP LaserJet 3600n Printer
Hp color laserjet 3600. It keeps telling me that
if you have used another printer on the same port # or local port. plug the cable into the 3600 and refresh the port. if its an ethernet port print th io sheet and make sure its holding its settings.
Oct 18, 2009 | HP LaserJet 3600n Printer
Aug 12, 2008 | HP LaserJet 3600n Printer
1,110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
