Question about Polaroid LCD-1750 17 in. HD-Ready Television
Polaroid FLM1511 LCD TV
I have inadvertently activated the child lock on this TV and the only way I can turn it on now is by the remote.(it just shuts down after 6 secs) To compound matters I do not have a remote. I have tried several universal remotes and cannot get the TV to power on. I just bought a new remote from polaroid ($30++) but it won't turn it on either. Is there any other way to reset the memory on this TV? Many thanks
  • wayne101 Sep 22, 2008
    I have the same problem with a Polaroid LCD 1700... whenevre I try to enyer he passworld, the stt closes the menu and goes to channel 0... anyone figure this out yet??
I have the same problem, but I have a remote. I have tried everything and nothing works. When I try to type in the factory set password under parent lock, which is all zeros, it immediately turns the television to channel zero! We didn't set this, it just started happening. The manual for this model LCD 2000, is worthless! I called the company and they too were worthless! The call goes to another company for some reason and they have the same manual that I do. Any help would be appreciated!
Posted on Jun 03, 2007
SOURCE:
My Palsonic LCD TFTV81PBHDT remote is broken and buttons on side panel do not seem to work. How can I switch tv on to tune to universal remote? Do the side buttons have some sort of child lock function...
you can program most universal remotes to work the tv and menu the child lock is activated on the tv and the buttons will not work only power button will work as long as it has not been set to not work when made. some are set this way. but a remote with the right code set will turn on the tv.
Sep 20, 2013 | Televison & Video
MY RCA TTE 20V500T TELEVISION IS STUCK IN CHILD SAFETY AND TURNED OFF W/NO REMOTE TO ACCESS THE MENU
Without remote its not possible to disable child lock. If it possible to arrange the remote then you can do the following to override the lock.
1.Press VOL+ on the remote and CHANNEL + on the
front of the TV at the same time. Enter New Pwd.
will appear on the screen. (You must be in the Enter
password screen when attempting this).
2.Press the number buttons to enter a four-digit code.
The code will appear on the screen as you enter it.
3.Press OK to save the code.
4.Press MENU repeatedly to exit the menu or the menu
will automatically disappear within a few seconds if
no buttons are pressed on the remote control
Dec 10, 2012 | RCA 20V500T 20" TV
I htink the child lock is on- how do I turn it off? a CD is playing now, and the kids want to put a DVD in to the machine
Go to menu on your or set up on your remote control. then, look from the features that says child lock .Use the arrows to move to another feature. If the child lock is turned on, click turn off by using the arrows.
Oct 03, 2010 | Polaroid TDM-1421C TV
My apex tv model AT2708S is locked and i can't find manual
CHILD LOCK The Child Lock feature prevents unauthorized viewing of the TV. To activate, press and hold the F key, and then press MUTE. You should see a key symbol appear on the screen. This will lock out all remote functions (except for Standby). To unlock the TV, press and hold the F key and press MUTE. This will unlock the TV. Please note that the only way to activate or deactivate the Child Lock feature is via remote control - please insure that it is stored securely.
Aug 20, 2010 | Apex Digital AT2708S 27" TV
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Thanx
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
Child lock on on Mikomi 15ldc250, got no RC
mikomi 15ldc250 child lock on but cant find remote control, how do i turn tv on?
Aug 25, 2009 | Televison & Video
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
How to undo Child Lock
the key "POWER" +"TV/AV",
Oct 24, 2008 | Televison & Video
Child Lock issue
Unfortunately the Child Lock facility disables the buttons on the TV.
You should be able to get a replacement remote control from an authorised Philips dealer, or you could try a universal remote control form most electrical retailers. Philips make a range of universal remote controls.
Instructions for activating and de-activating the child lock are in the manual. If you don't have the manual, download it here:
https://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
Polaroid LCD-1750 17 in. HD-Ready Television Logo
234 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
