After sitting for a few minutes the water dispenser will stop working. Resetting the unit by toggling the "unit on/off" button does let the dispenser work temporarily. Every other function works satisfactorily.
SOURCE: Water dispenser conditnues to drip after releasing the button
No seal or gasket on the water line... you do have a water valve that maybe sticking open .... and/or the switch in the water dispenser is stayng open...hope it helps let me know..
SOURCE: I have a sub zero
you have to get all of the air out of the line. Put a glass under the water outlet and press the water button. it wil take several minutes before you will see water
SOURCE: Hotpoint side by side water button does not
Your
water line could be frozen in the door. You can disconnect the line under the
unit before it goes into the door at the bottom hinge. Push the dispenser
button and see if it comes out there. If it does leave the door open till it thaws
