Question about Nokia 2610 Cellular Phone
My nokia 2610 not starting
Pressing red button for long time the screen shows up but coplete blank... then automatically switches off.... Please provide a way out... Also I know nothing about electonics, circuit boards etc... so what exactly should I do??
  • 580 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Nov 02, 2012
SOURCE: Nokia N70 Screen is White and shows NOKIA only
Open the back cover of the phone and remove the battery,the try blowing it hard where the battery pins are for 10 minutes or so then switch it back on.Your phone will run smoothly,but only for a short period.The best option is to press the *,green,3 at the same time after blowing the phone.if it does not want to work then let me know.josephsimaneka@aol.com
Posted on Dec 26, 2008
SOURCE: MY NOKIA 7610 IS NOT STARTING. WHEN I TURN ON MY
it is because your software is corrupted, kindly take you phone to the manufacturer for re installing the software,, thank you,, plz rate me,,,
Posted on Jul 05, 2009
jameel infot
  • 15 Answers
SOURCE: nokia 7610 not working
you need to format your phone but you may lose all your memory details. To format your phone hold the following keys{* button, green/call button, 3 button and the power off button}. Holding these keys will format your button.
bertus_kriel
  • 121 Answers
SOURCE: nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Posted on Oct 10, 2009
SOURCE: The front screen of my Nokia 2720 is just blank, how do I get to work
The micro ribbon wire may be damaged if its blank if the phone is old this may be the case opening and closing breaks the ribbon wire after time. If it is new return for replacement. also in menu, phone, display is where all adjustments are.
Posted on Apr 06, 2012
Hii My Nokia 5130 Express Music phone doesnt start up. It shows "test mode" on plugging the charger. Even otherwise, on starting the phone the Nokia logo appears ten the screen goes white and switches...
please format your phone using first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
Oct 20, 2010 | Cell Phones
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Nokia n70 is showing white blank screen
Oct 08, 2009 | Nokia N70 Cellular Phone
Unlock Nokia 2610
hi
here is the solution
Warning: Do not enter any wrong unlock unlock codes on your Nokia 2610 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2610 mobile phone without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2610 mobile phone.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2610 mobile phone would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2610 mobile phone
Each Nokia 2610 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 2610 mobile phone at www.mobileunlocksolutions.com. hope you do please rate me thank you...
Sep 20, 2009 | Nokia 2610 Cellular Phone
Nokia 7610 not working
Jul 05, 2009 | Nokia 7610
MY NOKIA 7610 IS NOT STARTING. WHEN I TURN ON MY PHONE IT IS SHOWING BLANK WHITE SCREEN WITH SOME RED LINES SOMETIMES,IT IS GETTING SWITCH OFF AUTOMATICALLY AGAIN. PLS SUGGEST HOW TO FIX IT.
A virus?
jonats,
question: have you tried charging your phone and does it indicates a display or light ups your LCD screen and indicates charging?
1) if it does charging and indicates "charging" on your LCD screen , try to do this:
note: make sure your battery does have a charge when doing this
a) remove the battery and install it again , but dont put the power on
b) press and hold this 3 buttons at the same time: "call " button / " * " button / "3" button
c) while holding and pressing the 3 buttons, switch and press the power button and wait till a display appear on the screen.
cheers.
mark
Jan 17, 2009 | Nokia 2610 Cellular Phone
How do I switch off my nokia 2610
press and hold the red button that you use to cancel or disconnect calls till the phone starts to shut down. the phone will switch off..repeat the same for switching on as well
Dec 07, 2008 | Nokia 2610 Cellular Phone
Nokia 6020 won't start up
Unfortunatly check info service usually means your phone is moisture damaged.Especially if the screen goes blank.Check if the charger unit has turned slightly green and mouldy looking.Take off the back cover and check the battery does not look warped and also remove the front fascia and check for signs of staining on the keypad.It is not a screen problem if the logos are still appearing .it is an internal problem.If your phone is moisture damaged there is no way of repairing it.Bring it to a mobile repair shop to get it opened up and examined.hope this helps
Sep 26, 2008 | Nokia Handsfree For 6020, 6101, 6102...
Nokia 2610 Cellular Phone Logo
62 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
