Question about Asko Dishwashers
HOW TO REPLACE DIVERTER ON ASKO DISHWASHER - Asko Dishwashers
Asko dishwasher D5233 -- food particles left on glasses after wash
Your best bet is to clean the wash arms and drain filters at the base of the dishwasher. If this makes no difference then it is likely the diverter valve is not functioning and causes the drain water to mix with wash/ rinse water.
http://www.repairclinic.com/PartDetail/Diverter-valve/8801389/1489040
See manual
http://www.ajmadison.com/ajmadison/itemdocs/Asko_5233_ADA.pdf
Apr 20, 2014 | Asko Dishwashers
How can I replace a diverter valve?
go and download www.fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 21, 2012 | Asko D3251HDSS Stainless Steel Built-in...
I have a asko dw20.1 dishwasher. When i turn it on the machine pump the water out, then it take new water in, and then it just stops? help..?
HI,
You either have a diverter problem or the unit can not determine how much water entered the tank on fill. Are you able to access base pan area? If so, is there water in the base pan? This is important to determine what your next move should be. If water is in the base pan, need to look at diverter under pump housing, look for water residue, this will tell you is the diverter has jammed or is leaking. I hope this helps.. Also around the door handle of the dishwasher door, you will find the model number like 3250, or something like that. With that number I can lead you in parts locating and problems related to yours model.
Looking forward to helping you..
Aug 03, 2011 | Dishwashers
It heats up, it seems to make the appropriate noises, but whatever water come in, never sprays, it just fill on the bottom.
Hi you may need a diverter or a motor to correct this problem. When you start the unit, it fills, does the unit click 3 times? Or how many time does it click? The reason is the diverter need to shift to the lower spray are to begin washing, if this does not happen, it will not run. I can look up parts for you if you like. Let me know..
Good Luck
Jul 23, 2011 | Asko D1706 Built-in Dishwasher
Asko D1996 dishwater does not turnon.
Check inside the machine for fuse or circuit breaker. Replace or reset. If repeats, you have to contact the service center.
Apr 14, 2010 | Asko D1996SS Built-in Dishwasher
Asko 1350 fill problem.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve if found to be defective.
Now, if the valve is ok, replace the control.
In most cases, this will be a control fault.
Jun 21, 2009 | Asko 1385 Dishwasher
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Dishwashers Logo
109 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
