Question about Rheem Water Heaters
Manual for a Rheem tankless water heater model RGT- 53
  • Rheem Master
  • 5,089 Answers
Copy following link for troubleshoot resources, including variety of Rheem and Paloma manuals:
RGT-53 does not show among more recent models, but the manuals are generally generic.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Posted on Nov 02, 2012
gary1121
  • 332 Answers
SOURCE: rheem tankless water heater wont lite
the system was not sized properly, you need to have a 3/4 gas line to the unit for the volume of gas it needs, the tankless water heaters need to have every bit of gas that is says, it sounds like who ever installed di not make sure you had enough gas comming in the house, you might have to either have a new meter installed or run the gas lind directly from the meter to the water heater and cap off the gas line thats there
Posted on May 29, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
  • 244 Answers
SOURCE: I have a 1L error code. Can you help?
Hi stevenandarl,
Contact Paloma/Rheem customer (800-432-8373) support; tell them the code you are displaying. Rheem will send you instructions via email if you feel you can perform this operation yourself. Or they will recommend a professional in your area to help you.
Mike...
Posted on Nov 26, 2009
  • 48 Answers
SOURCE: what is trouble code C8 on a rheem tankless water
c8 is a cycle not a code... the code comes up after it, may look like a temperature... 2 digiti numbetr
Posted on Jan 16, 2010
  • 67 Answers
SOURCE: Can't find manual & have a C7 error code.
need to contact rheem what you can do until then is remove the control wire it will run until parts ship out
Posted on Jul 31, 2010
What is causing electric tankless hot water heater to be needing red button reset often?
PDF]Tankless Electric (RTE) Troubleshooting - Rheem
www.rheem.com/docs/FetchDocument.aspx?ID=87d15e35-5adf-4e9f...
Tankless Electric (RTE) Troubleshooting. Technical Competence .... For four chamber units (RTE18 & 27) go to paragraph 4T. 9. Conduct OHMS resistance ...
Rheem RTE 27 Series ' Use and Care Manual
https://www.manualowl.com/m/Rheem/RTE-27-Series/Manual/296033
Rheem RTE 27 Series ' Use and Care Manual - Page 1. Use & Care Manual Electric Tankless With Installation Instructions for the Installer Water Heaters The ...
Sep 06, 2015 | Rheem RTE 27 Tankless Electric Water...
Bought a rheem rete 13 off ebay
Question posted under Rheem tankless water heater:
Call Rheem at 800 432 8373
They will need serial number located on label on side of unit.
Usually I recommend that people tear out their tankless water heater and sell it on ebay, and then install tank-type heater from different manufacturer:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
I would be very reluctant to connect used gas appliance without a product manual, and service manual.
http://waterheatertimer.org/images/Exploded-house3.jpg
Mar 19, 2013 | Rheem Tankless Hot Water Heater...
Rheem pronto tankless water heater just barely warm model # 74pvn-1. This is in a house we are just purchasing. Also it looks like it may be attatched to another tank water heater , Help please
Before calling service technician, open following link for Rheem troubleshooting resources.
Sometimes people attach tankless to tank-type heater to preheat incoming cold water.
Additional tanks are also used to store solar heat, and some installations have tank-type because tankless is unreliable. Service technician can sort out the function correctly.
http://waterheatertimer.org/Tempering-tank.html
Owner should read tankless manual thoroughly, especially troubleshoot and maintenance sections. Tankless require yearly maintenance.
Since tankless are expensive to repair and replace, you might be able to fire up the tank-type water heater and provide hot water without much cost.
You can also install tank-type gas water heater yourself. Lowes sells 40 gallon for $317.00, and then you offer 10% less.
http://waterheatertimer/How-to-install-gas-water-heater.html
Apr 19, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
My Richmond tankless water heater is flashing the error code 76 and C8
Richmond is Rheem.
Following links are meant to assist resourceful do-it-yourselfer solve long term maintenance issues that tankless pose.
Error 76 is communication fault with remote control.
Check following links for Paloma 'Rheem" error codes:
http://www.palomastore.com/paloma_error_codes.html
http://www.palomatankless.com/owners/homeowner+trouble.lasso
Best place to start is your manual. Following link show typical Rheem manual with the words troubleshoot and maintenance throughout manual.
Read manual several times before buying product to see yearly maintenance requirement and complexity of tankless water heaters.
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Contact Rheem: they will usually kick you back to local service technician.
http://www.rheem.com/Contact.aspx
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Rheem website is not easiest to navigate, but manuals appear for current models.
Read other Rheem questions at fixya to gain wider experience with potential problems and solutions.
http://www.fixya.com/tags/rtg_74pvn
Install DIY tank-type gas water heater and avoid the whole headache
Post question on pro water heater forum: This is where I go to catch up on latest info in fast-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for answer at fixya:
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 17, 2011 | Rheem Tankless Hot Water Heater...
I am have a error code 72 C4 on a Rheem tankless water heater
Error 72 is Flame sensing Device fault.
Flame rod could need replacement or be out of line, or tankless needs to be cleaned using maintenance outlined in manual.
Read manual.
Open following link for Rheem tankless troubleshoot resources including error codes, parts links, typical manuals:
Oct 25, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Can't find manual & have a C7 error code on a Rheem tankless water heater model # rtg-74pvm-1.
Jul 26, 2010 | Rheem Tankless Hot Water Heater...
I have a 1L error code. Can you help? I have a Rheem RTG-53 PVP. Tankless water heater. Works great. Except for the Error code.
Hi stevenandarl,
Mike...
Nov 24, 2009 | Rheem EcoSense by 7.4 GPM Tankless Water...
Water Heaters Logo
111 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
