Question about Linksys Wireless-G WRT54G Router
Linksys WRT54G wireless router not compatible with Aztech modem?
My ISP changed my DSL modem from a Siemens Speedstream to an Aztech DSL 605 modem, and since then my Linksys WRT54G wireless router does not work (no internet connection) when used with the Aztech modem. Technicians suggested to plug cable to one of the output ports of my Linksys router, instead of plugging modem cable into input port. This provided internet connection until a new device connects to my Linksys wireless router. Should I change my Linksys router or change the DSL modem provided by my ISP?
  • tdkelti Jan 07, 2009
    need to change from static address to open address
  • cheesehead35 May 11, 2010
    Unplug everything, including power, plug it back in the proper way, modem into the WAN or Internet port. Does your router receive an IP address from your ISP? You can check this by going to the 'status' link on the web interface of the router.
    Problem Solver:
  • 15 Answers
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Posted on Jan 13, 2009
How to connecting Aztech modem DSL600E with Router linksys WRT54G
1.connect port 1 from the Aztech to the Linksys WRT54G Wan"
Login to the linksys and release/ renew ip
2. once IP is obtained then you should be able to connect.
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
I can't get my wireless g broadband router to work with my dsl speedstream 5100 modem i can connect to internet when my ethernet cable goes from my xp pc or my mac osx desktop directly to the dsl...
make sure that there is no IP conflict with the two devices. speedstream and wireless G. if both of them have same IP gateway you have to change the IP either one of them for you to have a connection.
Apr 04, 2010 | Linksys Wireless-G WRT54G Router
I have a siemens 4200 adsl modem i had a net gear modem before and that was not working with wireless internet and now this modem wont let me connect wireless either only with the ethernet cabel. help!
Hello Mate,
the siemens speedstream 4200 is a DSL modem/Router which doesn't have wireless connection. So even tough if you have a computer equiped with a wireless adapter, you will not be able to connect wirelessly because the siemens 4200 doesn't act as wireless access point.
You may need next time to check first if the modem/router to buy support wireless (wifi g or n) and make sure that it's not only a modem, it should be also a router.
i attached here some references for you from the top brands:
1. Linksys DSL modem/Router with wireless N: http://www.linksysbycisco.com/MEA/en/products/WAG120N
2. Linksys DSL modem/Router with Wireless G: http://www.linksysbycisco.com/ANZ/en/products/WAG54G
You can find other brands as Dlink, Netgear ...
Best Regards,
Oct 29, 2009 | Computers & Internet
How do I get my Wireless-G Broadband Router WRT54G to work with my Verizon Westell 2200 modem. I can get internet with the modem but not with the router
HI,
Your ISP is verizon DSL.
It is very easy to set up the router with DSL.
first check if you are ale to go online when connected only to the modem.
There are 2 types of connection for DSL.
For More information Click Here
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
SPEEDSTREAM 4200 MODEM CONNECTED TO WRT54G ROUTER WIRELESS DONT
turn on the wireless option in the router...
plug your computer into the router type in
192.168.1.1
username: admin
Password: public
go to wireless tab
turn it on
END!
P.S.
Also you have to be in range!
Sep 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Problems connecting Siemens Speedstream 4100 to a non-AT&T ISP
The answer is Yes,speedstream 4100 cannot be used in bridged conditions for any other isp
Jan 29, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
456 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
