Question about Cameras
Power adapter / transformer voltage, is this a safe combination?
I have a digital photo frame and lost the original power adapter. The sticker on the product says it uses 5V DC 2A. I found another transformer that will fit and power it but I don't know if this is safe. It is marked 5.4V 2410 mA. I don't know what the difference is and certainly don't want to damage the product or start a fire. Can someone confirm that is is safe to use the alternate transformer? Thank you!!
  • brosent88 Jan 12, 2009
    thank you, but can anyone confirm the volatage values on the replacement adapter that I am using are safe when compared to the original specs? Is there 'that much' of a difference? Thanks!!
    Scholar:
  • 185 Answers
Brosent88,
do not use a transformer that is not a match to the original. go to a radio shack or contact the company that made or marketed your frame for a replacement transformer.
Posted on Jan 11, 2009
  • John Buettner Jan 12, 2009
    brosent88,
    well 2410milli-ampers = 2.41 ampers, so you want to use a transformer that puts out .41 amps dc and .4 volts dc higher than what the equipment calls for ? unless there is a + or -- certain amount %in the instruction manual i would not use it.
Why wont my digital photo frame turn on?
If you have not already done so, try another power adapter. In some cases, the cord between the power rectifier/step down transformer (the part that actually plugs into the AC outlet) and the connector at the frame end, becomes kinked or broken. The connector at the frame may also have become worn and not propely connected? If a second adapter does not work then the unit is faulty. Take it to your nearest service center for repair. (it may be less expensive to purchase another digital frame?)
Dec 20, 2012 | Philips 7008 8-INCH DIGITAL PHOTO FRAME
Digital photo frame not switching on. Worked yesterday but not today. Would it be the adaptor or the frame itself, how can I find out?
If the adapter works with another device then the frame is bad. If the frame works with another power source then the adapter is bad.You can also measure the voltage between the contacts on the output end of the adapter to see whether you're getting any juice out of it when it's plugged in.
Apr 17, 2012 | Cameras
What can I use to charge my Pandigital with? I lost my charger!
Go to an electronics store and buy (or find one from an old gadget) a 9V (check the back to double check voltage) transformer. Good luck!
Jun 13, 2011 | PANDIGITAL 7" Digital Photo Frame With...
Can i buy a new transformer for my digital photoframe
If you can determine the voltage and polarity of the input (often embossed next to the socket) then you will be able to find a generic replacement. Most of these use a standard concentric plug that is a different size for different voltages.
There are power supplies that have adjustable voltages and an array of different connectors, although the single voltage ones are neater. You will also need to make sure that the power supply you get can provide enough amperage or wattage for your frame. If you still have the old power supply you can get the information off of it.
My first stop for buying this sort of thing is Amazon. You can also find many such items on eBay.
Nov 06, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
Where can a get a power adapter for my 10 inch digital photo frame that was lost? do you know the part number
Bring the photo frame to Radioshack. They have a large selection of universal adapters and can help you get one with the correct size tip and voltage.
Feb 27, 2010 | Philips PhotoFrame -10 Digital Picture...
No power
1) Try different wall outlets.
2) Turn the dial on the frame both ways to make sure the backlight brightness is not turned all the way down.
3) Test the AC adapter with a voltmeter.
If the adapter does not work, replace with one of the same voltage and amperage.
If the adapter does work, grab your receipt and go back to store or call the company.
Jan 06, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
SmartParts SP15MW photo frame won't turn on--pwr adptr shows 12 v
It's the power adapter... I had the same problem as of yesterday and today I used the power supply from my HDTV and it worked as good as new. Will have to go out tomorrow and get a new power supply.
Dec 14, 2009 | SmartParts SP15MW (092566981886) Digital...
Cameras Logo
198 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
