Question about Sharp AL2040CS Digital Laser Copier, Printer, Scanner
AR-163 problem my copy is operate but print only white plz help me
  • hamed_malaki
    hamed_malaki Jan 07, 2009
    toner is full
  • hamed_malaki
    hamed_malaki Jan 08, 2009
    yes i think may DEV is empty it s true?
    Genius:
  • 2,120 Answers
Replace the toner cartridge.
Posted on Jan 04, 2009
  • Leroy Elliott
    Leroy Elliott Jan 07, 2009
    Did you pull the tape off of the cartridge?
My AR-163 copier is bringing out half copy, it will copy and leave the down part uncoppied, how do i solve that problem
Half copy is never an issue with the toner. If you leave the lid open and make a skyshot copy what does it look like, is the copy all black with a thin white border around it, and do you see the scanner light comming on all the way across? You will want to make sure that your developer is evenly distributed across the magnetic roller. Also try looking into the score tron and check the drum cleaning blade and drum.
Oct 11, 2014 | Sharp AR-163 All-In-One Laser Printer
A brod white patch on centre con copy Sharp AR 163
check the developer in the developing unit maybe the developer is empty,then also check the charging assembly maybe its pour of toner just try to clean
Sep 03, 2010 | Sharp AR 201 Copier
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
SHARP AR-287
Is the code a H5 ? Is it a AR-163 or a AR-287? Is the copier making a load noise when making a copy? Basicly, the code means you are have more then 5 paper jams in the fuser & there is a problem there & the copier is locked up.... It's self saving it self
May 05, 2010 | Sharp AR 163 Copier
On sharp AR-163 I have white lines(text mising)from top to bottom ? It happens even when you print only
if you make a copy and the copy is ok but the print copy is bad . this sounds like you might have the wrong printer driver set up.
all sharp al-ar small copiers u must have the exact driver for coper model you can get them at sharpusa.com under personal copiers
Mar 11, 2009 | Sharp AR 163 Copier
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Problem with pdf formats
Yes should do if the printer is printing incorrect symbols then upgrade you PDF reader.
Thanks J
Dec 12, 2007 | Sharp AR-163 All-In-One Laser Printer
Sharp AL2040CS Digital Laser Copier, Printer, Scanner Logo
64 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
