Question about Frigidaire Affinity ATF7000E Front Load Washer
Computer board out on frifidaire affinity dryer
Computer board out
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Error code e 91 for frigadare affinity dryer
most likely faulty control board...........
cheers
Apr 05, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer runs but beeps intermitenly and doesn't stop beeping
you most likely have a bad computer board located in the top console.i haven't changed any of these boards out but on the frigidaire affinity dryer this happens alot and it's the computer board.the dryer would just start beeping on it's own,like 3 beeps at a time beep beep beep,then beep beep beep,was the board,you have to give the full model number to whoever you order the board from,open the dryer door,look around the opening where you put the clothes in and you'll see a tag with the full model number.good luck.
Feb 25, 2014 | Whirlpool GEW9868K Electric Dryer
My affinity frigidaire gas dryer wont stop running
Hello Kenneth Joynt - Often when a dryer will not stop running, it is because the unit may have a potential wiring failure, faulty timer, or a communication error with the main control board. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Apr 12, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Affinity dryer model FAQE7001LW0 OVERHEATS AND SHUTS DOWN
Therm o resistor or air ducts venting needs clean out
if not that change main board
Aug 13, 2012 | Frigidaire Affinity FAQE7001LW Electric...
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My Frigidaire Affinity dryer has and error message of E68 I have tried to reset and so far this hs helped what makes this happen and how do I stop it in the future? Thank you Sue Andrews
This is a fault code for a stuck key on the board. You may have to remove the control panel and check the keys. If this does not work you may have to replace the panel or control board.
Aug 01, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Hi my Frifidaire dryer model number feq1442es is making a metal screeching noise somtimes when it is running
With frigidaire, more than likely the rear bearing is going out on if it the screeching sound is happening. the part number for that is 131825900 and will run you about $3.00. Go to apdepot to order the part if needed.
Oct 31, 2010 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Clothes get caught in top front of dryer
probably the felt worn...very common on frifidaire models(also branded kenmore on certain models)
Jun 11, 2009 | Dryers
My affinity frigidaire dryer keeps flashing an E9E error code
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Nov 26, 2008 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire Affinity ATF7000E Front Load Washer Logo
179 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
