Question about Bosch Dryers
Lp to natural gas conversion bosch dryer
Hey Every one... I have a wtmc6500uc that is set up for lp. does anyone know how to or know where i can find a service manual?
    Top Expert:
  • Bosch Master
  • 9,472 Answers
Based on the information you provided, it sounds like the control assembly is the issue and needs to be replaced. Here is the control assembly you need to order.
The part comes with a 365 day, any part, any reason return.
Posted on Nov 02, 2012
catriver
  • 878 Answers
SOURCE: LP gas conversion on an LG dryer
Mr. D, make sure you have a little time, you have to remove a few things. 1. Remove the 3 screws in back which hold the top on. Slide the top back and lift off. 2. Remove the two screws on each end of the control panel frame. (inside). Disconnect the control panel harness, pull up and foward, place aside. Remove the 4 screws on the top of the front cover, disconnect the harness for the door switch and it should pull foward. Now I believe you can get at the gas valve on the lower right. Make sure to reverse the limiter as well as putting on the new orfice. If you need any further help, e mail me at catriver1@gmail.com Will be home this evening. Catriver.
Posted on Mar 17, 2007
Amigaman
  • 248 Answers
SOURCE: lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Posted on Nov 18, 2007
  • 184 Answers
SOURCE: converting my kenmore elite dryer from Natural gas to LP
MOST KITS HAVE AN INSTRUCTION SHEET WITH THEM.
USUALLY, THE ONLY THING YOU WILL HAVE TO DO IS REPLACE THE VENT CAP ON THE REGULATOR WITH A BLOCKING PIN AND REPLACE THE ORPHICE ON THE VALVE. BE SURE YOU CHECK FOR GAS LEAKS AFTER REASSEMBLY. BE CAREFUL NOT TO COME INTO CONTACT WITH THE IGNITOR. IT IS ON THE END OF THE BURNER.
IT DOES NOT BEND AT ALL. IF YOU PUT TOO MUCH PRESSURE ON IT, IT WILL BREAK.
Posted on Apr 08, 2008
jyackle5
  • 8197 Answers
SOURCE: Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Posted on Jan 19, 2009
  • 10 Answers
SOURCE: Convert Maytag Dryer to LP from Natural Gas?
yes it is very much necessary. the natural gas pressure is much lower that LP. it is @3.5 in, water column. The monometer is a pressure reading instrument that will tell what pressure is present at the gas source, appliance gas manifold and gas valve. Read the conversion kit instructions well. And adjust pressure according to data plate specifications. A u-tube water monometer is the best and most accurate however a standard analog will surfice. Please use caution.
Posted on Mar 07, 2009
I have a GWH1600h LP. can this unit be converted to natural gas with orfice change? If so, where to obtain the part. Thx much. Al
The 1600 series Bosch tankless water heaters, including the GWH1600H LP water heater, do not support a LP to NG gas conversion. Bosch does sell a gas conversion kit, 8719002176 , for the 2400/2600 and a few other water heater models. See http://www.prowaterheatersupply.com/bosch-therm-gas-conversion-kit-8719002176.html for the applicable models.
I wish that I had better news for you. See http://bosch-tankless-water-heaters.blogspot.com/2012/05/gas-conversion-for-bosch-retail-gas.html for some of the details. (The professional model water heaters are more likely to support gas conversion. However, it depends on the specific water heater burner/exhaust designs.)
Mar 05, 2017 | Kitchen Ranges
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
Convert Natural Gas Dryer to LP Gas
A dryer is a dryer. Most cases they all work the same. You will need to get an LP conversion kit for that model to complete the task.
Jan 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
REQUIREMENTS.
Jan 19, 2009 | Dryers
Conversion from natural gas to LP
there was no direction with the parts
Sep 14, 2008 | GE Profile DPSB620GCWW Gas Dryer
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
Dryers Logo
104 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
