Question about Canon Office Equipment & Supplies
How do we retrieve scanned documents from a Canon C5800?
We recently picked up a used Canon C5800 Imagerunner copier/printer/scanner. We have successfully connected it to our LAN, and can configure and see mailboxes. We can also scan documents so that they reside in the proper mailbox. The problem is that we do not know how to retrieve these scanned documents. We can get into the mailbox from a PC or Mac connected to the LAN through a Web Browser, and see the document in the mailbox. But all it seems we can do is download a small thumbnail. How do we retrieve the full scanned document(s)? thank you, ---- Brad
    Master:
  • Canon Master
  • 641 Answers
Hi. the mailbox is for internal use. you cant rettiene document from there . try to install and use canon color network scan gear .
Posted on Apr 30, 2017
SOURCE: Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Posted on Jan 26, 2008
  • 168 Answers
SOURCE: Can not scan documents using Canon Image Runner 2200
you need to down load the network scan gear tool www.imagerunner.com support downloads office /production then look for canon network utilities... down load scan gear tool [ not color}this file will have to be unzipped then run it... this will set a program in your program files open the one that says scan gear tool when opens either type in the device ip adress or you can select discover. once you do this you select it as the scanner in your scanning software Adobe Pro etc. you also must select scan on the copier then online before scan will happen
Posted on Dec 17, 2008
gunninfo
  • 59 Answers
SOURCE: Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Posted on Apr 20, 2009
iservice
  • 318 Answers
SOURCE: How do I scan a document to send as an attachment
First your company must have a e-mail server.Enter the server ip address in the smtp server address in the additional funcktion,system settings,network settings page untill you get the smtp server address.
Posted on Nov 10, 2009
  • 20 Answers
SOURCE: I'm trying to figure out how to scan a document
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Posted on Apr 15, 2010
I Need Manual for ir C5800
Send me email on emma.servis@gmail.com.
Aug 29, 2011 | Canon imageRUNNER C5800 Copier
Error 000202-0002
this is an issue with the home position sensor for the scanner check the home position sensor blow it out or try swaping it with another sensor this will get rid of your error
Jan 28, 2011 | Canon imageRUNNER C5800 Copier
We have Xerox Machine Canon IR C5800. the problem is while copying after more than 200 or 500 copies the machine copying is slow down i.e., may be 45 copies per minute.
This is normal behavior, you ask for 500 copies in a row it is a lot, so to prevent overheating and premature where of the pickup rollers it will slowdown... You could try calling smaller batches at a time
Cheers!
Jan 21, 2011 | Canon imageRUNNER C5800 Copier
How to configure ip address in canon ir 400
if you want to configure IP adrress you have to righty clic on the LAN connection and select properties and then select internet protocol ( TCP\IP). select its properties and enter manual IP address 192.168.1.2 and sub mask net 255.255.255.0 and press OK and close dialogue box.
After that open run and enter ping 192.168.1.2 press enter if you got reply the printer is ready.
all this use when printer on and connected properly.
or call me after 8.00 P.M Cell : 9014363609
Aug 19, 2010 | Canon imageRUNNER 400S Copier
Does anyone know how to fix error E000602-0402 on Canon ImageRunner C5800?
You need to change the HDD, upload a new system, language, RUI,... Call service because you need the service tool software
Pls. rate
May 04, 2010 | Canon imageRUNNER C5800 Copier
Install to the router with ip
Any network printer is similar to connecting one more PC to the existing LAN by increasing the lat octet of IP , keeping the gateway same & dns---no entries.........sodeep
Oct 27, 2009 | Canon imageRUNNER C3200 Copier
I need configure ethernet for connection a my network
Press the additional functions (star in a head) key, system settings, network settings, tcp/ip settings, enter the details and re boot.
Jun 27, 2009 | Canon imageRUNNER C5800 Copier
32 people viewed this question
old marine
old marine
