Question about Pentair Air Purifiers
Because of an indication on my Compool Cp3400 Error # 2 (Solar temp. sensor) I can not start the gas heater for the SPA. By the way, my system for the pool and spa does not include solar heating. I
I've already installed two new sensors for the "freeze" and "water" temp. indicators. Also installed a new battery (small one, like a watch battery) in the back panel
2 Suggested Answers
ksqrd1
SOURCE: goodman furnace has 3 blinking lights, indicating pressure switch stuck open. Any help?
You have probably resolved this by now but i will offer this for other users. I had the same problem. In my case the issue was that the furnace was not level. Condensate would not drain out properly. When the inductor blower would turn on, this condensate would blind over the pressure switch resulting in the failure. Things to check for include: 1 - Air Pressure switch hoses are clear and dry. 2 - Air Pressure switch hoses do not sag and that they allow any condensate to drain out. 3 - all Condensate hoses and tubes are free of obstruction and can drain properly, 4 - Furnace is level or at least slighty sloped to allow condensate to drain towards the front, not back. This is critical and is the reason mine gave me so much trouble. I now have mine pitched about 1/2 inch. Make sure that the P-Trap has water in it at all times. Your yearly maintenance should include che king to make sure that it does.
Posted on Dec 22, 2012
My Eden pure model Gen 3 doesn't turn on ? The red light on front is lite and filter is clean Why not
Edenpure has a troubleshooting guide at this website: MY HEATER WILL NOT TURN ON.
  • Make sure the power source is good. Plug in a lamp to see if it works correctly.
  • Make sure the front power switch/button is set to the "ON" position.
  • Unplug the power for 30 minutes. Plug the power back in and try operating the heater again. This will reset the internal sensors.
  • Some heater models are designed to be operated in temperatures less than 75 degrees Fahrenheit. The heater will not operate when the temperature is too high. Test the heater in a room that is below 75 degrees Fahrenheit.
  • Bring the heater inside to warm up for at least one hour before operating if it has been stored in a freezing or near freezing environment.
  • Make sure the filter is clean.
  • Remember, it will take a few minutes for the heater to warm up. The fan will start to blow after the heater has warmed up.
Heaters FAQ
Dec 07, 2016 | Air Purifiers
My fan doesn't turn off after I turn the car off its a 93 Oldsmobile Kutless Ciara
There should be a temp sensor for the fan inline with the fuse block. Sounds like the sensor is reading improperly and needs to be replaced.
Jan 07, 2015 | Standard 1991-1993 Oldsmobile Cutlass...
Need to replace fan blade. doi just the other blade off or do i need a tool
You should be able to get the fan off w/ a small screwdriver & some needle nose pliers for the metal clamp that holds the fan onto the shaft. Look on Google for suppliers to get a new fan & clamp. It shouldn't be expensive.
Apr 04, 2014 | Ecoquest Breeze AT Living Air Purifier
Ep9r 500 speed button won't work keeps flashing f
The water level sensor fell into the fan. Unplug the humidifier from the wall, stick your hand in between the fan blade and locate the sensor. It is a small black rectangular piece the size of a nickel but rectangular and 3 nickels thick. It also has a 2 inch stem sticking out of that clicks back and forth when you push it. Stick the sensor back into the sensor whole and the flashing f will go away and the humidifier will come on again.
Feb 22, 2014 | Essick Air Whole House Digital Humidifier...
Er 2 Thermistor
There is a water temp sensor in the unit. That sensor has failed.
May 06, 2013 | Electrolux ICON Professional EDW7505HPS...
Goodman furnace has 3 blinking lights, indicating pressure switch stuck open. Any help?
The flame sensor needs to be cleaned. This video might help you understand how to clean the flame sensor.
Oct 05, 2012 | Goodman Manufacturing Goodman GMH950704CX...
Oreck Air 12GU Instruction Manual
First of all, thank you very much Joe for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.oreck.com/PUG/Air-ProshieldPlus-AIR12GU-userguide.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Jan 31, 2012 | Oreck XL Professional Air Purifier
My breeze AT unit comes on, but the fan does not move. how do I repair this
This unit has had multiple electrical problems probably due to cheap circuit board parts. I've sent many back for repair. Repair usually runs $242 last time I checked, or you could trade in for a new unit. They'll take $100 off the cost of a new one. Otherwise, you may be able to try taking it to a small electronics repair place. I don't believe it's that complicated but if the board is toast there's no repairing it.
Jul 19, 2011 | Ecoquest Breeze At Air Purifier
I have an older model Flair unit. I took it apart to try and give it a good cleaning and noticed that there was a small glass bulb-looking part with one of the thin wires was broken. Of course the other...
It's attached to the pulse radio-wave ionizer. It comes on when the unit is on to show the radio wave is working. It's not needed and I've never seen a replacement but Radio Shack could probably help you replace it if you wanted.
Jun 23, 2011 | Ecoquest Flair Air Purifier
Air Purifiers Logo
114 people viewed this question
Top Pentair Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Pentair Air Purifier Expert? Answer questions, earn points and help others
