Question about Horizon Fitness T82 Treadmill
Lube belt warning
Treadmill won't work and displays a message: Lube Belt. What do I need to do and how do I do it?
3 Suggested Answers
  • 11 Answers
SOURCE: what is meant when it shows "lube belt"?
You need to apply lube between the walking belt and the black deck surface. Most manufacturers use silicone lube. We sell a lube kit for our treadmills that includes an applicator and a bottle of liquid silicone.for around $20.
Posted on Feb 09, 2011
AJIN G
  • 6694 Answers
SOURCE: lubed belt but display still
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
Posted on May 04, 2011
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Belt feels like it slips when I'm walking
If the belt is worn on the underside you will definitely want to replace the belt. The link at the bottom will take you to a video on how to use a liquid lube on your treadmill. Lubricating the belt/deck every 30 days will prolong the life of the belt and the deck.
The friction caused by excessive wear on the belt and/or the deck can cause a high amp draw and make the drive motor work harder than it's designed to.
How to Lubricate Treadmill Using Liquid Lube Video
Jan 17, 2013 | Precor 9.21 Treadmill
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
Makes grinding noise and belt won't move
If it sounds like metal rotating on metal then it could be a a(roller bearings or b( motor bearings. LUBE INMEDIATELY. + DECK BELT LUBE VERY URGENTE, MAYBE YOU HAVE A WORN DECK TIME TO CHANGE THE BELT.
God bless you
Oct 01, 2012 | Proform 380 Treadmill Walking Belt
Proform 470 treadmill, belt won't run
see the video attached:
1) LUBE THE DECK BELT
2) LUBE THE ROLLERS BEARING
3) if this NOT has solution , you must test the a) motor y/o main motor board see the block diagram
God bless you
Jul 31, 2012 | Exercise & Fitness
My Epic 425 Mx motor won't run even though power is on and display works
try to RUN the software calibration for diagnose, troubleshooting, fix it.
2) LUBE THE deck belt , this happen because the lack of maintenance schedule, maybe the deck is worn and need replace it. see the video and picture
3) lube the rollers bearing too very well.
4) test the input voltage motor, if there are the motor NEED repair,tight any wires connector for loose
5)measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. use the DVOM OR VOM in both cases.
see the block d, tight any wires connector or wires looses
God bless you
Jul 29, 2012 | Epic 425 Mx Treadmill EPTL88105 !
Landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
May 08, 2012 | Landice L7 Executive Trainer Treadmill...
Need owners manual for a tempo 632T treadmill
Says to lube belt did that but still saying lube belt. Won't run when the safety key is put in
Feb 20, 2012 | Life Fitness Exercise & Fitness
Lube Belt displays on digital display how to reset or where to lube the belt.
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Jul 28, 2010 | Horizon Exercise & Fitness
Horizon Fitness T82 Treadmill Logo
32 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Craig Butler
Craig Butler
wtdash
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
