Question about Samsung Computers & Internet
HOW CAN I FIX AUDIO PROBLEM ON MY NETBOOK
IT PLAYS BUT NO SOUND OUTPUT
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 133 Answers
Go to Audio device through device manager and roll back the driver if it is istalled.
Right click on My computer>Hardware Tab>Device Manager>Sound, Video & Game controller> reight click on your installed sound device>Properties> Driver Tab> Rool Back driver.
If not solved the problem, then reinstall the sound driver and check. If not, then again contact me.
Posted on Nov 02, 2012
I have an older home stereo system that i would like to connect to my vizio tv. I have a 3.5mm audio to rca plug. Coming out of the headphone jack on the tv, it plays no sound out of the system. Although...
I suspect what you're wanting to do is take the audio output from the TV and run it through your stereo system to leverage the large speakers. Correct?
I suggest using the RCA audio jacks (red and white pair) on the back of the TV. Most TV's still have these. Some are tied to a specific component, and some are general for all sound coming out of the TV. You connect this to the input RCA jacks on your stereo system.
The headphone jack on the TV could also work, but I suspect it may have a low level output. I don't understand how you say your MP3 player plays fine through the headphone jack, as that's an output, not an input. Unless there's some other jack?
Sep 22, 2013 | Vizio 29in Class LED 720p TV - LED TVs
Disc plays but no sound
The problem can be in the laser pickup assembly all the way to a bad speaker, try headphones to see if audio is present, if yes! the earphone jack, speaker, and audio output chip is the issue, if no sound! it is more than likely the assembly.
Apr 16, 2012 | Polaroid PDV-0701A Portable DVD Player
What does it mean when my JVC stereo system comes on but there is no sound coming out
The problem is in the audio output ic, "loading system" first check that the speaker wires are not shorting, If okay! the audio output ic must be changed.
Apr 03, 2012 | JVC Audio Players & Recorders
My iPhone plays videos on the Internet but no sound comes out, why Is that???
If your having problems with no audio from youtube, myspace and flash video. I suggest this
When watching web pages with embedded Flash video or animation such as movie or video clip on YouTube and MySpace using Mac OS X, users may hear no sound. The no sound audio output problem happens despite video playback is fine, and the issue can happen on any web browser, i.e. Safari and Mozilla Firefox. Strange thing is that, when using other applications such as RealPlayer, QuickTime Player and VLC Player, the sound is played properly. And no audio output issue does not affect embedded QuickTime including HD contents on the web.
Apple Mac OS X support site explains that the no audio from certain multimedia content issue is caused by some audio applications that change the computer's audio settings to a sample rate that is too high for other applications to use. The notorious programs include certain versions of Real Player, VLC Player and Audacity.
The solution to solve the Internet movie no sound or audio output is to reset the audio setting in Mac OS X to original configuration:
  1. Open "Audio MIDI Setup" (/Applications/Utilities/), then check the "Audio Output" setting.
  2. Change the "Audio Output" setting to 44100.0 Hz.
  3. Quit Audio MIDI Setup.
If the Audio Output setting is grayed out or disabled, go to "Properties For" tab in Audio MIDI Setup, and select "Built in Output".
I hope this helps
Dec 14, 2010 | Apple iPhone 3G
I don't get sound from Vizio Sound Bar, need connection instructions.
You have a red and white composite audio cable the simplest way is to hook that to your audio output on your tv then obviously the other end goes into the soundbar. Make sure its an OUTPUT not input on the tv, if you hook it up this way everything that plays on your tv will then play through the soundbar.Some tv's do not have an audio output if this is the case then you will have to hook it up to an output of another source such as DVD player or cable box. There are two other possible audio outs on your tv they are fiber optic audio and digital coaxil audio but usually not the case as they are usually only inputs. One other thing some tv's(very rare) require you to go to menu to enable audio out. There is one other possibity and that is HDMI which carries picture and sound but again TV's rarely have this output.
Dec 13, 2010 | Vizio Televison & Video
The sound on my Dell laptop has suddenly gone very tinny and distorted. Does anybody know what the cause may be and how I could fix it without calling Dell in India?! Thanks
I would use the audio output of your netbook to supply signal to any external audio system so you can determine is it is an internal circuit problem or simply a failed speaker. If the distortion is present in the sound output from the external system, then a circuit in the netbook has failed. If it isn't audible in the external system, then a junky speaker has failed in the netbook.
Oct 24, 2009 | Samsung NC10-14GW Notebook
Acer ax1700-u3793 doesn't display an hdmi sound output option
try to check if the audio cable(jack) is properly connected to your device or speaker
Aug 30, 2009 | Acer Aspire AX1700-U3793A PC Desktop
Hi! when i play music on my lap top, it plays but no sound. pls help
you may need to take following steps:
Check Volume from the volume control
Check the sound output device is selected the same as your sound card in control panel, sound and audio devices section
re-install sound drivers
Dec 20, 2008 | Computers & Internet
Alpine cda-9853 no CD audio
do you have an amplifier powering your speakers? if so make sure you have the correct remote wire and not the auto antenna wire
Sep 15, 2008 | Alpine CDA-9853 CD Player
Philips lx3600d
Common problem with the Philips - here is how to fix this issue:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Dec 20, 2007 | Philips LX3600D System
Computers & Internet Logo
62 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
