Question about Vanguard International Blue Flame - Medium Open Flame Patio Heater
I have a vanguard natural gas ventless heater, the piolet is lite but the dial goes from 1-5 it wont go on until it hits the 5 mark so there is no 1-4. it just goes wide open what could the problem be?
FixinFax
  • 3085 Answers
SOURCE: Hello,
You have a bad THERMOCOUPLE. Try a Appliance Parts Store or online with your model number. Had to find.
Posted on Nov 29, 2009
  • 2902 Answers
SOURCE: what color is the piolet light on a blue flame vanguard heater.
Hi it is blue with a slight yellow tip
Posted on Jan 26, 2010
SOURCE: how do I convert vanguard VMH26TPA wall heater
You would have to get a conversion kit, which usually
is new orfices and a spring that goes into the gas valve. The kit would probably be cheaper than buying a gas valve and the orfices seperately
Posted on Feb 11, 2010
TheMobilian
  • 8220 Answers
SOURCE: change from natural gas to propane
You could do it but it would be very expensive. You would need to change the ODS pilot and the gas valve itself. I am not sure even then it would work correctly. These are not conversion ready.
Posted on Jul 26, 2010
  • 674 Answers
SOURCE: I have a vanguard ventless
First, can you smell gas when you push for the pilot? If yes, look at the tube where the pilot gas comes out. Sometimes there is a small hole or 2 in the tube before the opening where the gas comes out. This is to allow air to mix with the gas. They sometimes become plugged with lint or dust. Check for this and let me know what you find.
Posted on Oct 28, 2010
How to I start my heater
If it is this heater, then you must:
1- turn the toggle switch to the ON position.
2- Turn the gas valve dial to the PILOT position.
3- Depress the pilot button while pressing the ignitor until you see a flame. Continue to depress the pilot dial for about 30-60 seconds.
4- let go of the button, and the pilot flame should stay lit. If it does , then turn the gas valve dial to the ON position.
5- Set the temperature and your done.
Apr 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
VN18TB PILOT LITE GOES OUT STAY LITE TILL HEATER COMES ON AFTER THE HEAT RUNS AND TURNS OFF THE PILOT LITE SHUTS OFF NATURAL GAS VANGUARD
Sounds like a weak thermocouple. With the extra heat of the main burner running it can keep the pilot solenoid open...without it it fails shut. Try replacing the thermocouple. (small rod the pilot flame burns against with a skinny copper tube going to gas valve).
Jan 04, 2010 | Heating & Cooling
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 19, 2009 | Vanguard International Vanguard BY Rheem...
Vanguard International Blue Flame - Medium Open Flame Patio Heater Logo
46 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
