Question about Magic Chef Ovens
Oven thermostat Chateau by Magic Chef Model RT742-5TV
Overhead oven will not maintain temperature. 1972 Timberline 20ft travel trailer According to Timberline answer man this model number was installed at the factory. Model # RT 742-5TV C2 BTU rating top 5200, Oven 10,000. The pilot light operates and when the oven control knob is pressed in and turned to 350 degrees, the oven main burner lights. Using an oven thermometer the oven will heat to 350 and continue heating until the thermometer is pegged at 550. Can you help? Thank you Gene
2 Suggested Answers
  • 114 Answers
SOURCE: The main burner won't light the pilot light gets
You have a defective pilot safety valve. Due to the age, the part may no longer be available. If you can find it, have it changed by an authorized gas technician. Also replace the pilot orafice. It should be a .014 orafice.
Posted on Aug 20, 2009
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
I have a magic chef S68-3cxw electric stove/oven. It is flashing f2 can anyone advise what F 2 stands for
Hi, the F2 code on the Magic Chef Oven implies that the Oven temperature is too hot.
The solution is to replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness...
Oct 09, 2010 | Magic Chef Ovens
Oven doesn't maintain the correct temperature.
The first suspect is the temperature sensor or oxidation on it's wiring connector pins. If you have an ohmeter you can measure it. It should be about 1080 ohms at 70F. As sthese ovens get older the control board tends to develop problems that cause this behavior. You can have the board rebuilt at fixyourboard.com.
Aug 20, 2010 | Magic Chef Ovens
We have a Magic Chef in our park model trailer. It has smelled and has heavy black soot inside the oven since day one. Any suggestions or reasons for this?
Make sure the gas valve has been set on the lp selection and not the natral gas one. This will cause the problem if cooking with the wrong setting on the oven control valve.
May 31, 2010 | Magic Chef Ovens
The main burner won't light the pilot light gets bigger it's a Magic Chef Chateau overhead oven
Aug 20, 2009 | Ovens
We own a 1973 TravelEze travel trailer with a magic chef lp 4 burner range. The model number is unreadable. It does start with BT22 we think. We would like to order a replacement gas regulator and a m
I think you should have more numbers. there are quite a few other series for this unit. I have posted a site below for your assistance.
http://www.aaarv.net/bt22_series_parts.htm
Please rank if this helped
Apr 27, 2009 | Magic Chef 9122 Gas Single Oven
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Ovens Logo
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
