Question about ANEST IWATA IWA4292 Hi-Line Kustom HP-TH Airbrush
Cap blowing off
Cleaned still not working
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 137 Answers
Try this link: http://anestiwata.com/product/airbrushes/
then click your model, the manual is right there, next to product description.
Posted on Mar 07, 2013
Olds 98 regency
May be the filter it's capped or the avaporative panel it's capped too with fine dust. Clean de filter and check tehe avaporative panel an cleaned too. Or, if the a/c it's working with low pressure in sucction side , may be need more refrigerat. Check this, thoe pressure in low side is 65 psi. but if the pressure is lowest than this may have a little leak and need fix it..
Aug 24, 2014 | LG LP123HD3A Terminal Air Conditioner
Will not start following rad hose repair?
this is odd! some how did you get the cap wet? pop cap and dry it out. coolant will feel greasey,break clean and a wipe of a rag will work. do the same with everything else under cap,blow dry. check wires. make cure youy did"t knock something loose. check for spark,fuel,i"m sure you did"nt do something to loose compreson! need fuel, need spark,need compression....what is mission? this age car does"nt have much more
Aug 21, 2012 | 1984 BMW 7 Series
How do I re-set a 10.1megopixel c1033
Chances are something is blocking the lens. It could be a lens cap, or your finger, or even a grain of dust or sand.
Here's the best first course of action:
1. Turn off the camera
2. Blow sharply into the areas around the lens/lens cap.
3. Turn it on again and see if that resolves the problem. Be sure nothing is physically obstructing the lens. (No lens cap, no finger, etc.)
4. If blowing doesn't work, try using a can of compressed air like you would buy at an office supply store, and blow out the area around the lens and lens housing. Chances are, if nothing was obstructing the lens that you could see, it might be a bit of dust or sand. Even a little sand can totally screw up the lens and keep it from moving in or out.
5. If this doesn't work, you should take your camera to a camera shop and have it professionally inspected and cleaned. Check out how much this will cost, though, before you do -- it might not make sense to pay what they want to charge, versus just buying a new camera.
May 05, 2012 | GE C1033 Digital Camera
RUUD Achiever 3 ton roof unit. Pops fuses. Place "hard" fuses in and it would pop the house's 60A fuse. Checked both motors and they spin just fine at the touch. Both caps also...
The compressor is going bad or the unit is charged wrong...
Whatever the cause the problem is the compressor locking up and blowing the fuses...
Clean the condenser coil...maybe the pressures are going too high...
If that don't work, then the compressor is shot or over charged...
Here is a tip that I wrote about how to clean your condenser
Cleaning Air ConditionerCondenser Coil with Pictures
heatman101
Jul 25, 2011 | Ruud UBHC Air Conditioner
Weedeater bv1850. pressure builder builds in gas tank after priming. none gets to sparkplug. If open gas gap gas pours out.
Your gas cap is vented to the atmosphere through a small rubber "duckbill" vent. You will see this vent if you turn the cap over and look at it. See if you can get any air to flow through the duckbill. Your gas cap appears to be clogged at the vent. Clean it and see if there is a difference. They sell new gas caps for several different model machines at Home Depot at a reasonable price. If you go there to purchase one, take the bad one with you for comparison. It may work after a good cleaning. Blow air through the top of it and maybe spray inside the top of it with some cleaner to unclog the dirt and debris buildup in the vent.
Dec 03, 2010 | Poulan Garden
I have a husqvarna 350, seems to have gas problem may be gas tank vent problem losen gas cap will run replase cap will run and then quit.
I would carefully remove gas cap and clean with mild soap and hot water using tooth brush to clean dirt and dust from both sides of cap. If possible blow out with air and mak sure it is thorgouhly dry before you put it back on your saw. If this does'nt help I would try anew cap. Hope this helps. Thanks
Nov 14, 2010 | Husqvarna Chain Saw 20" Bar
My py 90 wont start,
the same problem happened my py90 try taking out the sparkplug blowing in the hole to clean it out and if that doesnt work blow into the petrol cap really fast wen ur finished blowing put ur finger over the cap dont let any air out then kick start it about 6 times it should work on 2 kick starts but keep ur finger over the petrol cap
Feb 13, 2010 | 2005 Factory bike Chrono SM 250
Studdering and back firing when in drive and reverse not park
What year is it? if it has a distributor then remove the cap and use a hair dryer to blow it out and dry it with or buy a can of brake clean and clean the cap and the parts under the cap. Good luck hope this helps.
Aug 06, 2009 | Chrysler Town and Country Cars & Trucks
Oil cap popping off
The engine breather pipe is clogged ! clean it and the problem sloved!
Good luck.
Knight (Yamaha seca XJ750 A 1981)
Apr 14, 2009 | 2001 Buell M2 Cyclone
Bosch Dryer venting
i think you will find that one of these caps should be off and preferably connected to a vent hose to go outside the house. the reason they are blowing off is that the air has nowhere to go
Jun 26, 2007 | Bosch Axxis WTA 3510 Electric Dryer
ANEST IWATA IWA4292 Hi-Line Kustom HP-TH Airbrush Logo
97 people viewed this question
Top ANEST IWATA Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you an ANEST IWATA Craft and Hobby Expert? Answer questions, earn points and help others
