Question about HP Pavilion a6000n (882780985018) PC Desktop
HP Pavilion PC Desktop a6000 BIOS not working
HP Pavilion PC Desktop a6000 BIOS does not start. The fans are on. There is no display on monitor. Keyboard LED is not on. CD drive does not respond.
    Genius:
  • HP Master
  • 2,432 Answers
You have to considered this thing so you have at least an idea where the cause came from.
1. check weather the fan of the processor is rotating, if not mother board issue. make sure all the output voltage from the psu are good.
2.check the hard drive, if you can hear a spinning disc if none, that was mean it was a hard drive problem.
3.check if you can hear a beep sound then try to listen if how many times does it beeps.
4. before you tried to come up with trouble shooting the first thing that you can do is to check all the connectors and cable which may have loose connection.
hope this can help good luck.
Posted on Nov 02, 2012
SOURCE: CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Posted on Feb 10, 2009
sandro_monte
  • 72 Answers
SOURCE: HP Pavilion a705w PC Desktop\Ethernet Controller driver
obtain the driver from cd/dvd that was included as you purchased your desktop and try to check if the driver supports with the operating system you are using now. for example the driver available in your cd/dvd is only for windows xp and your operating system you are using now is windows vista of course driver not installed. try to download from internet the driver that are suite to your unit model and current operating system this can fixed your problem or else downgrade your os tha can support the driver that are available from your cd/dvd.
Posted on Oct 11, 2009
  • 644 Answers
SOURCE: My HP Pavilion a6300f powers up but no signal to the monitor
It could be the motherboard, try resetting the the bios first by either taking the lithium cmos battery out and then replacing after 30 secs or finding the the cmos jumber and unshort it for 30 secs, and reboot the mechine.
If the same and no monitor responce then the onboard graphic electronics may have failed, the motherboard does have a AGP expansion slot which you may want to test with a graphics card to see if that will work.
If you find that you do have to replace the motherboard, try to find one that uses the same processor and memory that you already have, that way you will keep expence down to a minimal.
Replacing the motherboard will mean you will have to contact microsoft to give you the installation codes for the operating system to work with the new motherboard, when you boot for the first time with the new motherboard fitted you will have to phone the number on the screen to reregister the system just follow the instructions, it is quite self explanetry.
Once all booted up and drivers installed the computer should run as normal, as for the hp recovery disks it should still work as all the information on the disk is on the harddrive any way, the only thing you would need to do is keep the motherboard installation disk with all the drivers on.
hope this helps.
Posted on Mar 23, 2010
Testimonial: "Thank you for taking the time to reply and for your suggestions."
SOURCE: HP Pavilion Elite m9517c Desktop PC stuck on welcome screen
hi
there is problem with windows OS
u have to reinstall wondows befor you go for reinstall just tak backup from you C drive
Posted on May 21, 2010
akgamit
  • 59 Answers
SOURCE: HP Pavilion a320n PC Desktop - won't turn on
Please visit the link given below and follow the steps to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=364171
Posted on May 29, 2010
Is Pavilion a6838f compatible with Intel E6750?
http://support.hp.com/us-en/product/HP-Pavilion-a6000-Desktop-PC-series/3883914/model/3935578/document/bph01767/ Go to this link and see which processor is on your system if it's the core 2 duo it may work but it will come down to the pins on the bottom of the chip and if the BIOS was programmed to go higher than the chip you have in there now. A lot of times the manufacturer limits the upgradability of their systems so that if you want more you will have to buy a newer system that has more in it than what you have now.
May 13, 2014 | HP Pavilion a6838f Desktop PC
Hp pavilion a6000
Is anything happening when you turn the switch off and on again?
If not you may be hanging on the BIOS somewhere.
Been "fiddling" around?
Jan 27, 2014 | HP Pavilion A6000 Series,amd Athlon 64 X2...
HP m9510f will not boot up.
no boot M9510f,
no boot is like the all time #1 complaint on PCs.
endless posts online on this and for sure at HP.. ever read their forums?
there real name is (and is supported still at HP) is
HP Pavilion Elite m9510f Desktop PC
no statement on screens, is the screen dead, and black
never once see HP logo, never see words to the effect
hit ESC to enter HP setup (BIOS) or F1 or F10 or????? do tell please.
that is first, forget windows now (its LAST)
screen model or maker stated ,
my guess a flat screen LCD
and the front button on it works and the screens local OSD menu works, right?
if PC is dead, the screen is checked first. for sure if BIOS screens in the PC are 100% dead, no text no F1,ESC,F10 keys prompted in text means PC dead or SCREEN dead.
here is HP page on your pc
https://support.hp.com/us-en/product/hp-pavilion-elite-m9500-desktop-pc-series/3824167/model/3876396/troubleshooting
here is black screen tests.
the screen (DISPLAY monitor) has its own brain
and is called OSD, on screen display
we check that first. always........ if screen is made before 2000 year
we trash it.... LOL (before first brains inside )
black screens, Desktop only.
http://pcdied.com/black-screen.html#DT-only
Jul 15, 2017 | HP Computers & Internet
My pc turns on but no beep or mouse or keyboard light flicker..fan works and cd opens and closes. resetted ram ,use another power supply still same result.. for an a6000 hp
This sounds like a problem I have just had with one of my PC's.
Try clearing the BIOS using the jumper on the motherboard, if that doesn't work (which it didn't in mine) then you may need to replace the motherboard (which I did).
Jun 06, 2012 | HP Pavilion a6000n (882780985018) PC...
Hi! My Hp Pavillion a1710n desktop emits a series of never ending beeps every time I turn it on, and nothing appears on the monitor. I checked and the monitor is plugged in. I dont know what's going on.
The problem with RAM or DISplay card(It can be Moisture problem) or Processor Fan is not working properly. Open the CPU case, locate RAM, remove the ram by opening the both side clips. and put the RAM back as it is. If you have Graphics card on your CPU then remove the Graphics Card also and put it back as it is. Start the PC with opened case to check Processor Fan is Rotating or not. If Fan is not working properly then you have to replace the Processor FAN. Fan ok but same problem persists. you have to replace RAM with new one. as well as Graphics (Display) card.
Jan 19, 2011 | HP Pavilion A1710N Desktop PC
Hp pavilion slimline s3100n doesn't display on the monitor. boots fine and fans spin and stuff, it just doesn't recognize its own VGA output. What do i do?
Hi
First,try hooking it up to an external monitor if you have access to one.Unfortunately,we need video to start checking for what may be wrong.
Try the monitor and post back to let me know what happens,and if it shows on the external display we can start looking at potential problems and fixes.
Bob
Aug 21, 2010 | HP Hewlett Packard Pavilion Slimline...
The monitor will not display DOS or Windows OS. It is integrated on Montherboard. There are no beep codes... I can see the light come on when I press the power button, the fan comes on, but nothing...
clean all the webs first... reseat the RAM ... Reset the Bios... Refer the Service or User manul for steps to the above.. then try powering on the sys.. 97% it will power on.. if it powers on first Update the BIOS of the sys.... Do well bye
Sep 20, 2009 | HP Pavilion s7310n (EN996AA) PC Desktop
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion a6000n (882780985018) PC Desktop Logo
565 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
