Question about Whirlpool Duet GHW9150P Front Load Washer
DL F error code
I've replaced emz part number 461970200692 two times and again am getting the dreaded DL error code. I've tried the "unplug and hopefully the computer will reset" method numerous times. Sometimes it work but I think I've run out of the limited tries and either need to replace it again or figure out why is keeps failing. I've taken apart the replacement part and figured out pretty much how it works. My question is....which direction is the "locking wheel" supposed to be in when it comes off the line?
Coldcut
  • 1554 Answers
SOURCE: Door Lock
I took the motherboard out and searched around for the crack with a microscope, I found that every one of the relays had bad solder joints with micro-cracks around the legs. This did not happen due to wear or vibration. It was just a bad solder job on the factory wave solder machine. QC issue.
After re-soldering all the relays legs I have run the machine for a month now without any issue.
So there it is the final fix for the dreaded door lock F dl issue. and likely any other random issue.
Posted on Jan 21, 2008
SOURCE: whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Posted on Jul 03, 2008
  • 62 Answers
SOURCE: My Whirlpool duet GHW9300PWO washer.
Be very careful on this one. It is a door lock code or main control board. Need more info.
Posted on Oct 20, 2008
SOURCE: F D/L and F11 error codes
I have a Kenmore (Whirlpool) front loader He3t that begin having the same problem after 2 years. I researched the problem and tried everything. The door lock mech. and all wiring was fine. Finally I stumbled upon a way to clear the error. (It still shows up once in a while.) The following has worked for me CONSISTENTLY about 25 times.
1) Remove top washer cover.
2) Disconnect the connector for the door switch on the control box.
3) Reach around and push any cycle button (normal, delicate, etc.)
4) Now hit the Cancel button.
5) Reconnect the door switch connector to the control box.
6) Reach around and push any button again. The clicking stops for me.
7) Replace the washer cover and use normally.
Hope this works for someone else!
There must be something getting latched up in the control board. And it gets reset.
Posted on Nov 11, 2008
tzweeb
  • 318 Answers
SOURCE: ''dl'' code comes on
the door lock switch has a solenoid lock to keep the door closed during cycles. if you tried to open the lid during a cycle then you may have damaged the lock and it should be replaced first.
if you still have troubles after that, then the control board may have an internal failure.
the lid switch costs about 30-40 bucks compared to 120-150 bucks for a board. try the lid switch first.
there is a test cycle you can run to check the lid lock if you want to do that also. but by starting a cycle it will do the same thing.
Posted on Jan 30, 2009
My 2007 Honda civic just had its battery replaced...So I've been trying to get my radio (and clock) to work again. The previous owner recorded a 5 digit code in the owner's manual. I've tried...
sometimes the code is put on the bottom of the ashtray just remove it and flip it upsidedown should be 4 or 5 digit number somewhere on it
Dec 09, 2012 | Cars & Trucks
NTI Shadow 5 gets altered
If the hard drive it's loaded on is very old or is almost full, then either replace the hard drive or get an external hard drive and install it there.
Jul 28, 2017 | NTI Shadow 5 Software
Dl and F flash when I'm trying to start the cycle...
sorry for the delay in getting back to you. you have a bad door latch mechanism on your washer that needs to be replaced.
Dec 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Machine reading F63
I hope a way to delete this code from the screen
I waited for 20 minutes and stopped flashing screen
Will not disappear
Press any buttons after the screen has stopped flashing
Jun 20, 2011 | Washing Machines
Code f dl
If you already replaced the latch, and still get fdl, then the problem is wiring harness to timer board or timer board connections, check them out.
Apr 11, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Code DL then F What does this mean?
i just finished fixing this problem on mine. DL = Door Latch. i am guessing you hear 6 clicks (processor trying to latch door) then the error. while i was poking around inside the unit i found a service manual inside (behind the bottom cover, remove 3 screws to gain access). the service manual reminded the tech to always try unplugging and replacing the connectors on the processor since oxidation is a major problem. the manual also noted the connector numbers (DS3... i think). i removed the top cover (3 screws on the back, slide back, lift off), found the processor, unplugged and reseated the connectors (did some others just for good measure), plugged the unint back in (ALWAYS UNPLUG BEFORE WORKING ON IT), and it worked. in case that doesn't fix it, you couldtry replacing the latch assy for about $50. good luck
Sep 17, 2008 | Kenmore Elite 45986 Front Load Washer
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
I got the F dl
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
most likely you will have to replace both door lock and ccu
Jul 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Problem
That is a door lock error code...check the latch and door strike for any damage, also try unplugging washer wait awhile and plug back in. If still get the f/dl than its time to replace either the door latch assembly or the main computer that controls it. Hope this helps - the doc
May 26, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
