Question about Microwave Ovens
Keypad won't work on model number hvm1540dn1ww General Electric microwave. How do I resolve this? I tried unplugging it and plugging it back in but nothing works
  • 38 Answers
Usually in this situation there is a problem with the panel just replace it there is a board behind it but iff the buttons dont respond then its most likley just the panel google the model number and you can get the panel
Posted on Nov 02, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: keypad on microwave wont work
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Sharp carousel Model R3A36 keypad not working
Your keypad has failed.
It would need a new control panel frame, which comes with the keypad.
You simply remove the circuit board and plug it into the new frame.
It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
Posted on Sep 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: The Keypad of my sylvania microwave does not work
Sounds like you have a bad membrane keypad.
To download owner's manuals for Canadian models of Sylvania microwaves, visit here, where you can also contact them.
For help with US models of Sylvania microwaves, contact Customer Service at 1-800-856-8977 (Mon-Fri 9:00-5:00 Pacific Time) or visit Galanz.
Posted on Dec 13, 2008
localwonder
  • 6784 Answers
SOURCE: key pad stop working
HI. this will happen over time if the microwave is used heavily and if it is over three years old. this key pad is attached to a smart board that you will need to replace. replacing the smart board will fix this issue.
Posted on Jun 06, 2009
garing
  • 998 Answers
SOURCE: how to change fuse in microwave
after cover is off should see fuse
Posted on Aug 09, 2009
Worth fixing HVM1540DN1ww?
most probably main transformer fuse blown. if fuse is ok & supply is ok on transformer input terminels.then replace magnetron
Jul 09, 2014 | General Electric Microwave Oven
The solutions to my microwave prolem (keypad reading commands but keys won't work)didn't help. Do you have a manual I could download?
Try:
1) Unplugging power and plugging back in
or
2) Press Cancel twice while door open (works on my Whirlpool).
Dec 23, 2011 | Microwave Ovens
Microwave oven General Electric oven flashing F3 how can I fix this model #JVM1440WH04
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks
Oct 22, 2011 | General Electric Microwave Oven
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
Install item # AP3993720 in a ge hvm1540dn1ww
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Jul 08, 2011 | GE HVM1540DN 950 Watts Microwave Oven
My GE microwave is beeping and the display says F3
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
We would need your model number to give you more specific info, part ordering info, and en estimate if needed.
Simply contact me here with your model number and symptoms for free help.
On some models, the membrane keypad is peeled off and a new one stuck on.
In other models, the plastic frame must be replaced, and it comes with a keypad already installed.
May 12, 2011 | General Electric Microwave Oven
Key pad does not work
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, I would say your membrane keypad has failed.
It all depends on the full model number, but on some, the keypads can be replaced separately, and on other models, it only comes with a new control panel frame.
Replacing this as an assembly is actually a pretty easy do it yourself job.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can get the control panel assembly here.
You can also find helpful exploded view diagrams at that link.
Just enter your full model number without any dashes.
If the keypad must be replaced on the existing frame, it's a much harder job. I have uploaded a handy guide with pictures showing you what's typically involved.
We do that job for $39.95 pluspart cost and shipping.
Feel free to contact me directly (and please remind me of your full model number) for more DIY help or a free estimate.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 06, 2010 | General Electric Microwave Oven
Keypad is locked on frigadaire 2.0 microwave oven
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Apr 28, 2010 | Frigidaire Built-In Microwave
Microwave Ovens Logo
229 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
