Question about Philips GOGEAR SA6045 MP3 Player
Headset in problem at socket pin side
Philips ipod gogear problem for headset occured, At bottom of headset knob problem observed so what i am do it will repair? or what to do?
My ipod is not opening and not connecting to the computer
Posted on Apr 09, 2010
  • 8,596 Answers
Try a different set of headphones - if these do not work, call Philips and redeem your warranty if it was purchased within the last year. Headphones can be replaced, but headphone jacls cannot be repaired.
-Tha Mp3 Doctor
Posted on Jan 05, 2009
Philips shm1900 headset on Lenovo thinkpad t430 with windows 7
It sounds like you are still using the mic on the laptop. Because you are far away from it, it sounds like echo.
Make sure the phillips headset is selected in the Windows mixer.
Make sure you are plugged into the mic jack on the laptop.
Make sure the mic is not muted. This is a default setting.
Apr 02, 2014 | Philips SHM1900 Headset
How do you pair the 903 headset with my ipod touch?
To pair the Plantronics BackBeat 903 with an iPod Touch:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the iPod Touch:
In Settings, choose General, Bluetooth, and turn Bluetooth on.
Choose the device on iPod Touch, then enter the PIN/Passkey 0000 (4 zeros).
After pairing the 903 and iPod Touch, the headset model may appear on the screen when you are viewing the audio or video playback controls. (You can "tap" to switch to a different audio output, such as the internal speaker)
Aug 17, 2011 | Plantronics BackBeat 903 Bluetooth Headset
Cant connect my em 227 with my ipod touch
Your headset is a monaural device, and, as such, bears bluetooth profiles HSP (HeadSet Profile) and HFP (HandsFree Profile) only, which are suitable for handling phone calls. The iPod Touch is not a phone, though, for what it must lack those profiles. It does have A2DP (Advanced Audio Distribution Profile) and AVRCP (Audio/Video Remote Control Profile), though, which are meant for stereo music streams. In order to have a bluetooth headset paired with your iPod, you better purchase a stereo pair out there. There are lots of brands and models available.
You know, for some platforms there are some applications which are able to route all audio sources to a monaural bluetooth headset. I don't know if there are any of such softwares in Apple's app market. You could search for it, if you want, but be warned that such arrangements use to result in pretty poor sound quality.
Please, let me know if I can help you any further.
Regards, Carlos
Dec 29, 2010 | Emerson EM227 Bluetooth Headset
Only one side of my philips headset works - how can I fix it?
Oftentimes you need to take it to a repair shop to get the wires re-run/connected. If it's a wired headset then you may have (and in my experience this is the most common) pulled the cord and some point and basically dislodged the cable from it's socket on one side - alternatively there may be a break somewhere in the cord.
Jul 21, 2009 | Philips Headset Headset
Haedset plug in
Hi Try with another headset, if this works you earphones are faulty, if still the same with new headphones then it looks like the phono socket needs replacing.
(if this helped please rate)
Dec 20, 2008 | Philips GoGear HDD6330 MP3 Player
How do i connect headset to panasonic kx-t7433
Just connect the pre existing speaker or earpiece through a newly installed E.P. socket.Whenever headset is connected to the E.P. socket, internal speaker will be disabled and external will be enabled. Same you have to do in the case of mic.Some more details are given below.
1.E.P. Socket = Earphone Socket ( With Series Switch, A SPDT switch is already attached to the inner side of the socket, whenever an E.P. Pin / Plug is inserted into the socket, It changes the position of the SPDT switch).
2.The inner speaker / earpiece / mic should be connected through the N/C ( Normally Connected ) Contact of the socket.
Aug 18, 2008 | Panasonic Lands Phones
Settin up bluetooth
Turn headset off.
Hold down the "phone" button on the headset.
Turn headset on.
Release "phone" button.
LED ring should be alternately flashing red/blue.
Voila.
Jun 21, 2008 | Plantronics Pulsar 590A Wireless Headset
Code i need the pass code for the bluetooth
It's real easy, the PIN code is 0000. That's right it's just four zero's, the PIN is the same regardless of brand or model of headset. So if you need the pin, here it is, and I hope this helps.
http://www.pchelpforanyone.blogspot.com/
Feb 16, 2008 | Philips VOX120 Wireless Headset
Philips GOGEAR SA6045 MP3 Player Logo
95 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
