Question about Refrigerators
Lg gr-t502g fridge compartment stopped working
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
  • 1891 Answers
SOURCE: LG Larder Fridge model GR-252 SBD IS FREEZING ON
this is a defrost problem . either the A D C a pc board on the back side of the frig . this main board controls the temp[t and the defrost . and has failed . repl it and problem is over .. mm hope this has helped .. feed back pls ..
Posted on Jul 22, 2010
Lg fridge GR-B3993LQ is not cooling
Make sure that the thermostat is working and that the compressor and associated fans are working (getting Power).
If both units are working and still no cooling your evaporator could be frozen because the defrost timer/element is not working. Worst case scenario is that you may have developed a small leak and lost refrigerant.
Mar 11, 2015 | LG Refrigerators
Lg express cool turbo gr-t452gva water build up in fridge
Drain pipe is in the freezer below where the fan(s) are. You may need to take a cover off to get to it.
Mar 20, 2013 | Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Mar 02, 2009 | LG LFD25860
Lg fridge freezer model gr-s352gca fault
Buy another brand. LG are cheap and nasty when it comes to whitegoods even though the price tag is still up there. I have done nothing but research for my next fridge and i might go with the same brand as i have had for the past ten years and have not had a single problem.(it is definately not a LG of Samsung or one of these other brands that have all the advertising and have only been around for a little while)
Jun 01, 2008 | Refrigerators
Mar 09, 2008 | Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
