Question about Cameras
Nikon d90. Built in flash not working.flash pops up , but it won't flash. Just keeps clicking.please help.
  • kakima Nov 02, 2012
    What's the problem? The video doesn't show the flash popping up. It merely shows the focus assist lamp lighting up.
  • 890 Answers
Have you tried fully charging the battery pack?
Posted on Nov 03, 2012
fblock
  • 289 Answers
SOURCE: I got the Nikon D90 . My popup flash won't go back in its place !
Sorry to hear this! Your parents should not kill you because of an accident. They may not be happy but you should not be killed. Don't force the flash down if it will not go because you may cause more harm. Your best bet is to have a pro look at it I'm sorry to say. REMEMBER - accidents happen or they would be called "purposes!"
Posted on Apr 27, 2009
  • 8 Answers
SOURCE: nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Posted on Mar 20, 2009
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
  • 7 Answers
SOURCE: Nikon D80 - My (built in) Flash will not pop up.
That is just a mechanical problem. There is just a little hook holding the flash and it retracts when you push the bottom to pop up the flash. I'm sure it can be easily fixed, never the less your camera store or Nikon should take care of it. So take it back to the place you bought it.
Posted on Aug 05, 2009
SOURCE: The built-in flash on my Canon EOS 450D camera won't pop-up
Had the same issue and just tried this....and it worls [PS dont use the littel plastic hotshoe cover as this keeps the microswitch depressed]
If you manually 'help' the flash to open and it doesn't pop; the microswitch under the rails of your hotshoe is probably stuck in the down position as mine was. I used a toothpick top pop it up and it works now!
Posted on Aug 27, 2009
Nikon D90 flash will not pop.
I suggest you take your camera to a Nikon camera repairer.
Apr 18, 2013 | Nikon DSLR D90 Digital Camera
Nikon d90 built in flash not working. Can anybody help with this problem please.when I have the camera in the correct modes the flash pops up but doesn't flash,but the pre illuminator does work.there
your flash is stuck.. you can just manually pull it up and it should work.. I have seen this a hundred times.... don't mangle it but a little squeeze and pull from the front should pop it.
Nov 03, 2012 | Cameras
D90 Built-in flash won't fire
Go in menu go to bracketing /flash then set for TTL
you should work to test leave lens cap on push button on left side with lightning bolt on it.
Oct 18, 2012 | Nikon DSLR D90 Digital Camera
My nikon d90 pop up flash is not working but the pup up is poping up
Hi Reggie,
Usually the pop up flash will extend when the program calls for it or the user has manually turned it on, and it will fire without an issue. Page 70 of the manual goes into detail how it is set up and uses graphics which won't work very well here. Unless you have the "circle with a line though it" over the lightning bolt "flash" symbol, the flash should fire when needed.
It is possible that the flash lamp has failed, and may need to be replaced. Contact Nikon Service & Support or other reputable camera shop to help you with that.
I hope this helps & good luck!
Mar 24, 2011 | Nikon DSLR D90 Digital Camera
The flash keeps popping up when I take a photo
The flash will come on because the light meter is reading that you need more light in order for your exposure to correctly turn out. If you think you don't need it, the flash will give you fill light. If you don't want it on, go into the menu, put the flash to "off" or run the camera in a manual mode and don't use the "green" auto mode. This should probably take care of it.
Jan 10, 2010 | Nikon D90 Digital Camera with 18-105mm...
The pop up flash on my D90 popped up one day, know I can not get it to shut, and stay closed. please help
WHEN U ARE IN AUTO MODE IT POPS UP. IN AUTO IT FIGURES OUT YOU NEED A FLASH. THAT IS WHY IT POPS UP.
U HAVE TO GO TO MENU TO STOP IT IN MENU. CHECK THE MANUALS
Dec 26, 2009 | Nikon D90 Digital Camera with 18-105mm...
Same problem..
If your camera is on the green Auto mode, it will pop up whenever insufficient light is indicated. Try putting the camera on A or S or M and see if that fixes it.
Sep 18, 2009 | Nikon D90 Digital Camera with 18-105mm...
My Nikon D90's built in flash is up and will not click back down.
I bought a Nikon D90 camera three months ago. Just yesterday I was using the built in flash. After using it the built in flash won't close. I did not drop it or bang it on any surfuce. I hear alot of people has the same problem. How can I fix this?
May 09, 2009 | Cameras
D90 flash
I have just fixed this problem on my D90. Go to http://dieselpic.wordpress.com/2010/07/14/d90-flash-wont-stay-down-how-to-fix/ to see how I did it.
Apr 08, 2009 | Nikon D90 Digital Camera with 18-105mm...
Cameras Logo
326 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
