Question about Samsung SD 608 (SD-608) Internal DVD Drive
Had some problem with connecting the DVD drive to the PC
Can you kindly give some instructions of how to connect the samsung octo edge DVD combo drive to the system?
    Genius:
  • 2,985 Answers
Depend on what you have in your system already. If your are replacing and existing drive simply remove it, and replace on the same IDE cable making sure the jumper is set to slave. Assuming you have one drive to the 0-IDE connector and the other connector is is to existing CD and this new drive is to be a second one. You will need another IDE ribbon cable. Set the drive to Master- connect the cale. position and fix the drive and plug the other end on the cable to the second IDE connector [Drive 01] See you mother board manual - connected a spere power connector.
Posted on May 18, 2007
Using your DVD-V4600, how do you play a vhs tape on TV? Need step by step instructions.
In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
  • You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
  • use either "RCA analog (red/white +yellow ) " or "SCART "or "Optic " cable.(any standard optical cable )...if exist ,optic is the best way to connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
  • pls also remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have octo edge samsung dvd writer.. it reads dvd's fine no problem.. but it burns dvd or cd. it stops burning between 10% to 15%. and shows input/output error.. then the DVD gets wasted.. Is There a...
make sure that the dvd rw is getting enough power test all leads that are attached to the dvd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrw/dvd rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the drivers could be on it
your drivers may have been corrupted or you might have a virus run your antivrus program
hope this helps
Jun 18, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
MY SUMSUNG DVD writer octo edge is not reading some CD and not reading DVD at all.
This issue is common to CD/DVD-ROMs. To fix this issue, visit my technical page at reyfrancisbasa2.blogspot.com for a graphical step-by-step instruction.
Thank you for visiting FixYa!
Apr 25, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I am installed with Cd/DVd drive of Samsung octo edge.The drive can red the cd'd but no dvd'd.What is the solution for this problem
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' 5.click on it 6.select your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer
Feb 26, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
My samsung octo edge cd-rw/dvd-rom combo drive is not working properly.i am not able to write files on it.i think its driver should be reinstalled.so how can i re install the driver?
If you do not have a disk with drivers go to the manufacturers web site and look for support or downloads to get the divers. save them to a folder you create on the c drive or go the driversone.com and put the info of your drive in and it will direct you to drivers then save them to the folder. Next you go to system icon in contol panel and then to hardware then device manager. look for cd/dvd drives and choose your drive then right click on it either disable it or reinstall the driver. If this helps please reply as this helps me continue to answer questions here and good luck
Apr 29, 2010 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I m using samsung octo edge dvd writer in nero i m unable to find write dvd option How can i write/burn dvd plz help!
To use "Burn DVD video files" in Nero, you have to switch on Advanced mode instead of standard.
In my version, this is what the bottom right corner of Nero StartSmart Essentials looks like in the two modes.
Apr 10, 2010 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Samsung dvd rw with octo edge dvd rom says burning failed for dual layer disc
I will presume that you do not have a combo DVD.
If you have a "combo" drive, it doesn't burn any DVDs.
First, has the burner ever burned dual-layer DVD's successfully?
Radio Shack has a laser cleaner ($13). Read & follow the directions. It is an audio CD with a row of brushes. No chemicals involved.
Recommendation:
Use Verbatim DVD's, they are the best. Samsung is also a top brand.
Oct 02, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Dvd rom detecting problem
You need to find what DVD reading and CD and also DVD burning software you had, then download versions of the programs compatible with Win 98--then they should work fine. Your CD/DVD drives will be ignored until you get the correct burning software installed. Go t Samsung, which hopefully will have the appropriate downloads for Win98. If Samsung no longer has what you need, find any software for Win98 such as Roxio, or hopefully freeware, and you should be back in business.
Feb 12, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Samsung SD 608 (SD-608) Internal DVD Drive Logo
70 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
