Question about Kenmore Refrigerators
Noisy fan in freezer stops when refrigerator doors open not when freezer opens
Lately our Kenmore French Door refrigerator model 795.78409.802 has been making a weird (and loud) humming noise, apparently from the freezer section. It isn't constant, and seems to be worse at night for some reason. We had seen some ice on the back wall of the freezer, I presume near where the fan is, so we scraped that off and it seemed to be a little better. The next day, the noise was just as bad and there wasn't the icy build up on the freezer as there was before. When we open the refrigerator portion, the noise stops, but when we open the freezer, the noise just continues and sounds louder, which is why I assume it's the freezer fan that is causing the problem. We couldn't get either the drawer or the door off of the freezer to get "up close and personal" with the back of the freezer, so I don't know if there's something else going on or not. Any suggestions? The space for our fridge is very limited and this was the only one that would fit in our tight spot when we had to replace it 3 years ago. Not to mention, we can't afford to have to buy another refrigerator so soon after buying this one...so any help/suggestions are appreciated. I can't stand the noise...this has got to be the noisiest refrigerator I have ever had the displeasure of owning. Thanks for your help!
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
The noise you hear is more than likely the fan hitting on ice buildup on the coils and you need to replace the "defrost thermostat" located on the coils in the freezer. Here is the part to order.
Here is a video to walk you thru the process. The model may be different but the process is the same.
Keep me posted.
Posted on Nov 02, 2012
BNewberry
  • 93 Answers
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Posted on May 15, 2008
  • 1314 Answers
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Posted on Mar 28, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
SOURCE: Loud Freezer Motor noise
I don't usually buy the service plan but I did for this unit (hey it's gen 1). The service guy said he has seen this problem quite a bit and that LG created a new RCM board to fix it (part# BBR34917104). Apparently the OEM board didn't detect the ice build up on the fan motor very well. I had the new board installed two days ago and defrosted the freezer. So far so good, I'll post again if I have any further issues.
Posted on Oct 05, 2008
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
Freezer has constant noise. When we open freezer drawer, noise stops. Could this be the fan?
usually the fan runs with door open as well. how ever u may have a problem with fan hitting something if it has come loose or off its support bracket, if u have an ice build up in freezer usually due to defrost problem the fan may make funny noises also
Mar 13, 2015 | Samsung RF4267HARS Stainless Steel French...
When freezer drawer is closed, very noisy. Noise stops when you open freezer door. Is is the fan?
It sure sounds like the fan is either just going bad or there is possibly is hitting the blades. if it is a buzzing sound then ice is probably the problem. if it is a rattle or squeal then the motor is bad.
bad evaporator fan motor or fan motor blade or ice build up that is building up by the evap. motor or evap motor blade.
Oct 10, 2014 | Refrigerators
Our Kenmore 596-76533500 bottom freezer/French door fridge stopped cooling. Please please help?
check the evaporator fan . open the cover and see if defrost problem occured
May 13, 2014 | Kenmore Refrigerators
My Jenn Air French Door Professional Refrigerator makes a strange annoying knocking sound. It seems to come and go and happens for a few seconds to close to 1 minute. It will stop soon after I open the...
You have two fans and a compressor which could be making the noise. Inside the freezer behind the back cover is the evaporator fan. It probably stops running when you open the door. Hold the door switch down to keep the fan running to see if it's making the noise.
the compressor and other fan is under the unit accessed from the back behind the cardboard cover.
Nov 30, 2009 | Jenn-Air JFC2089HE French Door...
Grrr noise that stops when doors are opened
The noise you are hearing is probably the fan blades hitting some ice build up. Un plug your refrigerator for over night and it will defrost melting the ice. If it still makes the noise after that then the fan motor is going bad, you will need to replace it soon. The reason that it stops when you open the door is because the power is cut off to the fan when you open the door.
Nov 20, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Noisy LG Fridge Freezer
most likely the evaporator fan is hitting some ice that has formed on the mounting shroud. You will have to defrost the unit by leaving it off over night. Also what contributes to this broblem is the location of the temp sensors. they should be checked that they are in the holders for them and not buried into the foam insulation. There is on in the ref on the top of the liner and one in the freezer. These pop off. remove them from the foam and insert them into the holders. If you can't do this then it may be wise to use a service person to do check it.
Dec 18, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
1,658 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
