Question about Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor
Flashing green power indicator lamp.
I turned off and disconnected the monitor to try a different one. When I try to hook up the Sceptre again all I get is a black screen and a flashing indicator lamp. I have tested both power and monitor cables and they are good. What am I missing?? hard to believe the monitor went bad just by diconnecting and then reconnecting it. Thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sceptre Master
  • 848 Answers
Flashing green power indicator lamp? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
Sceptre LM004 Power Supply Backlight Inverter for X9G KOMODO
Posted on Mar 22, 2015
    Genius:
  • 2,985 Answers
Check out the data plug- you may have bent some pins.
Posted on Jun 01, 2007
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Flashing green led on my hanns-g HX191D
Try it on another PC fIrst.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
The monitor ligh just blinks on red then green, but no image
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Sceptre monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 28, 2010 | Sceptre 17" LCD Monitor
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
I just replaced the lamp on my sony wega 42WE655 tv and the lamp replacement indicator light onthe front no longer indicates that it is bad, but the standby light keeps flashing red. when i try to turn it...
If you just replaced the lamp then there's something wrong in the power circuit or you have a bad lamp. If you can I would take the back cover off and look at the board where the power cord connects and lok around it for swollen capacitors. Let me know if you find anything.
Oct 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My sceptre monitor S1902D won't turn on just stopped
If the monitor has no power at all then you have a dead power board, or a broken power cord, test also a different wall AC outlet.
If instead there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Mar 06, 2009 | Sceptre S1902D 19" LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor Logo
180 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
