Question about Toys
I lost my key to an arctic cat four wheeler and i wanna hot wire it?
5 Suggested Answers
  • 10865 Answers
SOURCE: do i need a certain wiring harness to put a winch
your artic cat may have a plug for your winch and again it may not. Call any artic cat dealer and tell them what you want to do. Have them recommend a winch that is compatable with your 4-wheeler and get a price that includes installation.
Posted on Oct 02, 2009
SOURCE: how do I start my sons atv without the key(hotwire)
Simply unplug the key switch you might find the electric start works too if not should start by hand of coast start every 4 wheeler I can ever remember always started this way hope that helps good luck
Posted on Aug 25, 2010
nutznboltz08
  • 36 Answers
SOURCE: carburater schematics diagram for a 2004 arctic cat 300
Go to http://www.arcticcatpartshouse.com/arctic-cat-atv-parts.aspx?aribrand=ARC#/Arctic_Cat/2004_ATV_300_4X4_GREEN_MRP_%28A2004ATF4AUSS%29/CARBURETOR/A2004ATF4AUSS/A2004ATF4AUSR.
Posted on Oct 13, 2012
plink_plonk
  • 1807 Answers
SOURCE: How do i hot wire my 97 trail blazer polaris four wheeler i lost my key show picture
https://www.youtube.com/watch?v=2up2iV2Ovp0
This should help. I know its a different quad, but same principle
Posted on May 23, 2016
I have a 05 arctic cat 400 atv. My problem is that it's has constant fire to the coil, with the key off and I can't figure out why.
sounds like the switch may be shorted, or a wire(s) have shorted to one another.... Find the plastic connector for the switch and unplug it... it should not fire.. if it does.. maybe someone has hot wired it??? ... BE CAREFUL!!
2005 Arctic Cat 250 300 400 500 650 ATVs Service Repair Workshop Manu
Arctic Cat ATV repair manuals
Arctic Cat ATV Service Repair Manuals
Arctic Cat ATV Service Manuals Online
Jul 15, 2017 | ATVs
Why will my arctic cat 4 wheeler not turn off when I turn the key off
If it carries on running as though you haven't turned the key, there can only be two reasons. Faulty switch, or faulty earth somewhere.
If is falters, carries on a bit and then stops, usually caused by carbon build or which is glowing hot and igniting the mixture after the key is turned.
Jul 28, 2016 | ATVs
The starter engages and starts the motor fine when the motor is cold. however if you ride and try to restart the starter just spins and you can only start using the kick stater.
"ATV" service and repair manuals - CRXSi.Com
www.crxsi.com/reference/manuals/atv/
.. arctic cat 400 4x4 engine · 04 arctic cat 4x4 400 4 wheeler manual trans startergears ... 2000 2x4 red atv artic cat repair manual · 2000 300 arctic 4 wheeler instructions .... 2007 arctic cat 90 c c four wheeler wiring diagrams · 2007 arctic cat 90four .... Atv Arctic Cat 2010 - Arctic Cat Dvx 300 And 300 Utility Service Manual ...
Aug 12, 2015 | Arctic Cat 2007 90 DVX 2x4
Arctic cat atv
It Is not getting lubrication to part of the engine. Take it to a shop before you destroy the engine.
Apr 09, 2014 | ATVs
Arctic cat problems
Check for spark if it has spark your carb may be dirty or not jetted right if it's not your carb or spark your valves may need to be adjusted
Dec 22, 2013 | RTO 200cc Full Size Four Wheeler ATV
Arctic cat 4 wheeler hard to start, keeps turning over and over and then finally starts
weak fuel pump, choke not working ?
Here are the service manuals for all Arctic cat ATVs
Oct 06, 2013 | Arctic Cat ATVs
2004 arctic cat 650 twin back fires and pops at carb. rear exhaust pipe getting red hot
Hi Shawn, Check the ignition timing and inlet manifold gaskets and all vacuum hose connections. If all is okay carry out a compression test, looking specifically for burned valves, but timing would seem to be the likely problem. Regards John
Oct 05, 2013 | RTO 200cc Full Size Four Wheeler ATV
07 arctic cat charging problems any ideas
voltage regulator... new battery (first) meter should read 13+ volts over 4k rpm and up
Jan 13, 2013 | RTO 200cc Full Size Four Wheeler ATV
Do i need a certain wiring harness to put a winch on my arctic cat four wheeler or just the one that comes with the winch and that on the four wheeler it self
Oct 02, 2009 | Sport & Outdoor - Others
Toys Logo
472 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
