Question about Refrigerators
Hot spot on fridge/freezer
Kelvinator no frost 355 fridge/freezer does not freeze too well nor cool either although it will freeze vegetables. The freezer at the top has a small amount of accumulated frost on the sides and a frozen ice puddle on the bottom but most noticeably the lower outer ledge of the freezer door opening between the fridge and freezer is very hot to touch. This heat transfer might explain why the freezer is not so cold.
Can you please suggest how to remedy the hot spot?
It is a very old fridge which still runs and has shifted house a few times in its life. It doesn't make abnormal noises nor is it overly full or airflow around the outside of the fridge restricted. I haven't checked or cleaned anything yet coz i'm not sure where to start. Are there drain holes inside the freezer that maybe blocked. The thermostat will still regulate the temp.
  • deanissuprem Jan 16, 2009
    Update: I have defrosted the fridge and freezer using a hairdryer and cleared the drain at the back of the freezer. Once the ice was chipped off the fan inside the freezer it immediately started to spin, however it hasn't moved since the appliance was completely defrosted. The freezer will now freeze stuff as long as it is sitting on the cold metal floor of the freezer but not if sitting on the shelf.
    It is now my understanding that the hotspot on the ledge between the fridge and freezer is caused by the heater of the defrost system. The heater does not turn off, although at times it seems to be cooler to the touch. I tried to gain access to the heater by removing the doors and attempting to remove the cover panel but stopped as it looked as though i would have to bend it to clear the tabs on at either end and being metal it will never be straight again. There is no access from the back.
    The timer by the compressor can be heard ticking at times but the heater remains on whether or not the timer is on, also, whether or not the temp sensor (inside the fridge screwed to the cooling thingy) is inside the fridge or not; I unscrewed it, moved it outside the fridge and closed the door for a couple of days to see what would happen.
    The compressor can be heard cycling on and off.
    It seems that everything was working but the heater was always on. i don't have a multi meter to check the electrics.
    Is there a simple trick to access the heater or maintenance step I can perform or is this a job for a professional?
    An explanation of what maybe happening or advice would be appreciated oh great GURU. Thanks for your time.
  • 109 Answers
SOURCE: GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Posted on Mar 31, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
Maytag317
  • 1136 Answers
SOURCE: Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
Posted on May 10, 2009
tborn6
  • 700 Answers
SOURCE: GE GSS20IEPAWW Freezer Not cold outside of freezer very HOT
check to make sure that the fan in the back is working and then clean the condenser coil underneith the frig
Posted on May 24, 2009
  • 555 Answers
SOURCE: water accumulating in vegetable bin on model
This is caused by a clogged drain tube or the door is not closing correctly. Be sure the seal around the fridge door is closing correctly. If not, the drain tube needs to be replaced or cleaned.
Posted on Nov 06, 2009
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 05, 2011 | Frigidaire Freezers
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
My frost free freezer stops freezing although it stays cold and then I have to switch it off for more than a day before it starts freezing again
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool Refrigerators
My fruit and vegetable drawers keep freezing my fruits and vegetables. What could be causing this to occur?
Hello, Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.the air deflector....
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control I hope this will help....
Oct 31, 2010 | Refrigerators
How does the control panel work? low numbers warm etc?? I inherited my partners mothers fridge freezer, unfortunatly it didn't include the instrution book,I have had it running on number 2 but it seems to...
Typically the larger the number the colder the setting. Is there an arrow on the knob that points to the left or right that says "warmer" or "colder" I also question your comment "freeze too much" because this is a freezer only, it will not keep things "cool" if you turn it up enough. If you mean there is frost on everything that is humidity and not the freezers fault.
Jun 03, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
I have a Kelvinator 500L Twin Air No Frost and the freezer no longer freezes anything and the bottom of the fridge is just cold enough but won't respond to temperature adjustment. The motor runs 24/7 as...
I am pretty sure its the defrost timer not working so freezer coil is iced up preventing cool air circulation .you can call me on 0415867792 if you want to know more charles
Nov 11, 2009 | Refrigerators
Kelvinator freezer is not freezing!
you mean it cools but not as afreezer ok, rework again the system properly vaccum and slowly charge it but please watch out the proper amperage of the compressor or might be the compressor motor now is weak, how old this unit,sir.thankyou
Aug 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Refrigerators Logo
693 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
