Question about Refrigerators
Kenmore coldspot not working properly after power outage
Lost power from Sandy. Borrowed a generator 24 hours after power went out to juice it up, then power came back about 18 hours after that. Icemaker still had ice last night, so we thought everything was fine, but came home to find things defrosting. The compressor sounds like it is working. There is cold air blowing, just not freezing cold air, Any suggestions?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
I am glad you made it thru the storm OK. I am in New Orleans and I am no stranger to what you guys went thru.
First, are you sure the compressor is running?
Post back to me.
Posted on Nov 02, 2012
3 Suggested Answers
SOURCE: Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Posted on May 23, 2008
markfreedman
  • 312 Answers
SOURCE: came home and all the ice has melted in icemaker
There is hope but not a great deal. That clicking sound you hear is the compressor (that part of the refrigerator that creates cold air) trying to start. It may be very hot. The reason usually is that there is dust clogging the coils at the base of the unit that must be cleaned out. There is a fan motor, usually mounted in the back of the fridge in the base next to the compressor. That fan may not be turning. If that is the case, the compressor will shut down to prevent overheating (a good thing).
Here is what you should do.
0 Pull out the fridge taking care not to damage the water line to the ice maker
1 Unplug it to let it cool down completely.
2 Put your salvageable food into camping coolers with bags of ice.
3 Purchase a long skinny refrigerator coil cleaning brush (I've seen these at Walmart)
4. Change into real work clothes. This will be a dirty job.
5 Remove the "grille" on the front of the fridge, at the base. Just pull it straight off.
6 Brush out the dust from the coils from the front bottom.
7 Replace the grill.
(Sorry. Your not done.)
8 When the fridge is out from the wall (you will want to sweep and mop what you see back there)
9 Remove the cardboard cover from the rear. (You will likely need 1/4 inch or 5/16 inch nut driver to remove hex head screws). Observe the cardboard covor as you will need to bend it to remove, after the screws holding it are off. (You may also want to wear gloves keep fiberglass from getting onto your skin.)
If you accidentally tear the cardboard, don't fret as it can usually be fixed with duct tape.
10 Now after all that,(which really doesn't take long). You will be looking at a black metal case with small pipes running out of it. That is the compressor.
You will also be looking at (depending on the design) a condenser fan.
11 If there is a Condenser Fan (usually on side-by-side refrigerators) then finding out if it works or not will be part of the diagnostic steps.
12 Plug in the fridge after it has cooled down completely (several hours) and see if the compressor comes on.
It may come on instantly. If it does check to see if the condenser fan blade is turning.
If it is not turning and the compressor starts to run. shut the Fridge down.
13 Check to see if there is an obstruction to it turning (such as a small toy). If there was an obstruction, plug the fridge back in and see if the fan now turnes. If it does, you have likely repaired the broken component.
14 If the fan blades does not turn, unplug the fridge again and replace the condenser fan motor.
You will need some tools to do this such as a 1/4" socket set, Wiring tools, Wire Stripper, Wire Nuts, Wire Ties. A handy man level of experience is required for replacement of this part.
15 When done replacing it (or removing the obstruction), make sure the back cardboard panel is reinstalled. It is vital to the efficient operation of the fridge.
16 Plug the fridge back in. Give it two hours of running time to see if it will start to cool. Probably will. If not, there could have been a refrigerant leak. If so, only a professional is licensed to do the work. If there is a refrigerant leak, then the repair is likely not recommended.
I hope this helps
Best Regards,
Mark
Posted on Dec 26, 2010
Kohler 30KW standby keeps throwing Under Voltage code - HELP PLEASE
The UV code has nothing to dow ith oil, poor oil would cause under frequency (low engine speed) Under voltage is caused by excessive load, short in the rotor/stator excition system, and/or AVR automatic voltage regulator. Of course loose wiring to will also cause it.
Feb 08, 2013 | Kohler 30 KW LP/Propane Industrial...
Kenmore Coldspot 25ssa. After power outage the refrigerator trips breakers and GFCI
Either the compressor or the start device on the compressor is shorted out. More than likely the compressor, hate being the bearer of bad news
Jun 07, 2012 | Kenmore Refrigerators
Furnace wont run ...thermostat battery went dead i replaced the batteries and still furnace wont run...We recently had a power outage for approximately 12 hours. This furnace is in our garage. we had...
Hello, The first thing you need to check with a multimeter is if you are getting 24 volts between the R AND C terminal on the intergrated control board. If not than the transformer is blown and needs to replaced or the fuse on the control board has blown and will need to be replaced. When check for 24 volts at the R and C terminal make sure the door switch is pushed in, u can just use electrical tape to temporaily hold the switch in. If you are getting 24 volts at R and C and notthing continues to run than the intergrated control board is most likely the cause and must be replaced.
Feb 04, 2011 | Goodman GMS90703BXA Heater
I have a 25KV stand-by generator made by generac. It is powered by a 4 cylinder mitsubishi engine. All works well for about 24 hours then the generator will shut down. If I install a fresh battery, it...
You didn't say if this is gas or diesel. My guess is gas (propane or natural gas) which means it has spark plugs. You have a charging system problem. The engine gets enough spark from the battery to run for 24 hours, and the charging system isn't able to keep up so that drains the battery until there isn't enough juice to get the plugs to spark and it quits running. It could be your alternator, or your voltage regulator (which might be inside the alternator). Remove the alternator and take it to a service shop. They can test and fix or exchange it. A temporary solution would be to connect a battery charger to the battery and leave it in place while it runs. That should provide enough juice to keep it running indefinitely, or at least quite a bit longer. If you hook up the battery charger so that it is powered by the output from your generator, this could work as a longer-term work-around - since it will only provide juice to the battery while it's running. I hope this was helpful. Al K
Jul 26, 2010 | Electrical Supplies
Kenmore Coldspot is on but not cold after power blackout
The reset is called a klickson it is inside that black cover on the side of the compressor.
sometimes they do fail.
Dec 28, 2008 | Refrigerators
Monitor 2400 heater will shut down when I run My generator
A UPS unit might work. Electronics need steady clean power.
Dec 18, 2008 | Intel CASE 350W PWRS ALLIED W/ 24PIN +...
Kenmore coldspot
HI.
i guess u will benifit from this link
plz rate this post
click here
BEST REGARDS
Aug 11, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
