Question about Giottos Photography
It looks like a MT8170 tripod. The screw that holds the head broke. I am unable to get a secure hold on either screw to disengage the screw from the head and the tripod rod.
Not able to remove the screw from the head or and the head post. The screw are too short to get unddo with a pliers.
  • 685 Answers
Send the tripod to:
Spartan Photo Center
197 east saint john st
Spartanburg SC 29306
Repairs are 425 + parts + return shipping. Just depends upon which parts you will need at this point.
Posted on Dec 15, 2012
SOURCE: Manfrotto Tripod Ball-grip Head 322RC2
If you look on the ring that goes around the ball, on the side by the red tension gauge, you'll see an indentation. It is just barely visible on the product shot above.
In the hole, you'll find what looks like an odd shaped bolt. It is actually a threaded post inside a nut.
Use an Allen wrench (hex key) to tighten this post.
Be careful though, a little tension here goes a long way. You should probably turn it no more than 1/8 to 1/4 turn and then test it. If it still isn't tight enough, repeat until you are satisfied.
You should probably also talk to a trained technician at somepoint to see if the loosening is indicative of a larger problem. I really wouldn't know one way or the other. I just discovered the calibration post by taking mine apart.
Posted on Nov 25, 2007
  • 24 Answers
SOURCE: Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
Posted on Jan 30, 2009
SOURCE: Removing Tripod head from center post on Manfrotto Modo 785B
I have the national geographic branded version. Here is how you remove the head.
(1) remove the center post from the tripod
(2) lock the ball head with the trigger lock
(3) grasp the body of the ball head with one hand and the center column with the other.
(4) turn counter clockwise.
If you're intending to replace the ballhead, be warned that the thread is non-standard. I have a new "plug" with a standard 1/4" thread made for free by the machinist at my job. I don't know how you would go about adapting it without such a capability.
Posted on Feb 06, 2009
  • 685 Answers
SOURCE: damaged Manfrotto 410 junior geared tripod head
Try www.BogenTripodParts.com for that part. It is not listed on their site, but they can most likely get it.
Posted on Jun 25, 2010
  • 685 Answers
SOURCE: Missing Tripod parts
Without knowing the brand of tripod i cannot help. There are some brands of tripods that are made for the retailer and the name is licensed, so the name brand does not support or stock repair parts. Especially if the tripod is an inexpensive one. Because of the model and make of you tripod, I would recommend you throw it out and buy another one. In my opinion Slik and Manfrotto are two very good ones. Slik for the lesser expensive and Manfrotto for the more durable, expensive, parts are almost always available unless is it really old tripod. Find some Manfrotto tripods at: www.BogenTripodParts.com
Why can't I find a replacement part?
Available replacement parts for Sunpack tripods are pretty much limited to new heads, mounting plates, or carry cases; take a look at what B&H Photo has to offer. You don't say what specific tripod you have, but I'd suggest a search at eBay where several are available at auction right now. Furthermore, a check of completed auction/sales shows both new and lightly used ones sold in the past month for between $10 to $50. Buy one for parts or use it as is. You won't find any part plus shipping for less than that.
Sunpack makes consumer not pro level tripods even though the term Pro may appear in some product names. When you buy a tripod that costs $400 and up without the head, you get more options for replacement parts. I have a Sunpack myself for lightest duty when hiking, but my main tripod is a Manfrotto with the grip head. The huge difference in cost makes a corresponding difference in what parts I can find online. When my Sunpack broke (in a different way than yours but equally unusable) I used gaffer's tape to hold it together until I could find a new one (on eBay for $15).
May 07, 2014 | Sunpak Photography
Head won't secure to tripod
Two potential issues. 1. Perhaps you have just not screwed it on tight enough. Just tighten the black knob as much as you can then screw the head on your legs as tight as you can. 2. If you can't even do that I will assume that the hole on the bottom of the head is too large for the screw on the tripod legs, in which case you just need a a bushing adapter. Like this one:
http://www.bhphotovideo.com/c/product/882988-REG/Sunwayfoto_tn_15_Bushing_3_8_1_4_Stainless_Steel.html
Apr 10, 2014 | Gitzo Gh2750qr Series 2 Magnesium Off...
How much weight will the Velbon Victory 250 Tripod hold?
The tripod will certainly hold this weight. However the limiting factor is the head. Without knowing the head you have mounted on the tripod I'm afraid I can't tell you whether it would hold your camera and lens.
Jul 30, 2012 | Velbon Victory 250 Tripod With Quick...
Remove 3130 head from 3021 tripod
The head is mounted on the base by a 3/8" screw. The head is held in place by 3 set screws in the base. Turn tripod upside down, loosen (or if completely removed, do not lose them) those 3 screws, turn tripod rightside up and unscrew head from tripod. If unable to turn head, loosen screws a little more. If scres are removed and heaf still not comeing off, Use pipe wrench or afjustable pliers wrapped in cloth to preven maring and loosen. (looking from top, or birds eye view, turn head counter-clockwise
Apr 23, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
Damaged Manfrotto 410 junior geared tripod head
May 25, 2010 | Photography
Radian pro Gt head broke that holds the scope.
You can still order the plate that attaches the camera/scope to the head from Eagle Optics directly at this link:
http://www.eagleoptics.com/tripod-accessories/vortex/radian-pro-gt-quick-release-plate
Feb 10, 2010 | Radians Radian Pro-GT Tripod
701RC2 going on 745B sticks
Hey SkipHall,
As in most Manfrotto tripods this tripod should have 3 set screws underneath the head mounting surface. Unscrew these set screws and you should be able to unscrew the current head off the tripod by holding the center column and turning the head counter clockwise. Installation of the new head should be the reverse. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Manfrotto 745MF3 Tripod
Photography Logo
145 people viewed this question
Top Giottos Photography Experts
Steve
Alcolu John
Alcolu John
Level 1 Expert
Tony Parsons
Tony Parsons
Are you a Giottos Photography Expert? Answer questions, earn points and help others
