Wonderfire 2610 burner plate where can i find one
Wonderfire 2610 burner plate part # 500-2932
2 Suggested Answers
SOURCE: I need tips on installing a new burner plate and
I have a Wonderfire gas stove and it's easy to replace the burner plate and gasket. Hardest thing is getting the bolts out. Use a vise grips and you won't strip them. I don't use any adhesive on the gasket just clean everything off and replace.
Posted on Nov 05, 2010
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
I need a replacement control knob, part no 0577299, for my Wonderfire President gas fire, model 950-0117, GC no. 32-815-10
If it is just a know with a half moon, you can get one @ most hardware supply houses.
Dec 17, 2013 | Heating & Cooling
Am told that a cozymizer gas fire installed in conventional grate now requires additional ventilation. Only id marks on plate are "18N and input 9.6 kw. Can you advise?
I just happened to be looking at this site. I have just changed a Cozymiser for a Wonderfire (remote control). For fires over 7kw, you will need a vent in the room - which will cause a through draft. Our Cozymiser was 9.2 kw and without a vent, it was against regulations to use. These regulations came in after we acquired it in 1989! Our new 7kw fire is great and a vent is not needed.
Oct 10, 2011 | Heating & Cooling
I have a wonder fire model 2610 and I need to replace the gas log set #500 2933 , please let me know where I need to go. Send reply to ss529@aol.com. Thank you. Dennis schnell
Dennis the Wonder Fire Gas Logs & Fireplaces are pretty much exclusive to Australia. So dealers there can probably help you. I have provided links to two different dealers that you may contact,
http://www.nectre.com/index.php?page=wonderfire
http://www.cradlemountainfireplaces.com.au/products/gas
I hope this helped you and thanks for choosing FixYa. Cheers
Sep 21, 2011 | Heating & Cooling
I need tips on installing a new burner plate and gasket on a Wonderfire 2610 gas heater
Oct 08, 2010 | Heating & Cooling
ON THE CAST IRON BURNERS THERE IS A PLATE WERE THE BURNER INSERTS INTO THE GAS VALVE. THIS PLATE CAN BE ADJUSTED TO ALLOW MORE/LESS AIR TO THE BURNERS BY SWIVELING THE PLATE .CANTHESE BE REPLACED
This 'adjustable plate' is known as an 'air shutter' located at the tips of the venturri tubes which are the tubes that carry the propane from the valve to the burner. These air shutters allow you to control your flame by mixing oxygen with propane to create a yellow flame to a blue flame. The perfect flame is a uniform blue flame with a small yellow tip.
Unfortunately, these air shutters are considered part of the burner itself and cannot be individually replaced. However, if the burner and venturri tubes are separate from each other, you may be able to get a replacement venturri tube without having to replace the entire burner unit.
Hope this helps.
Ben
Tanks 2 You Propane
propanetanks2you.com
Mar 30, 2010 | Lynx Grilling
My jenn air espressions gas cooktop has four burners. When
Remove the round burner plates and clean thoroughly in soap and water. Clean the burner ring where the burner plates rest with soap and water.
Let me know what you find.
Dec 13, 2009 | Cooktops
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
