Question about AOC Computers & Internet
Is Nvidia Geforce 210 compatible with AOC e1620Swb monitor?
When I play Warcraft & others games, the screen becomes black and says input not supported.
  • 3,606 Answers
Hello i guees you have to uprade your graphic driver
with the newest one.
This is the drver for XP:
http://www.geforce.com/drivers/results/49741
And this is for windows 7 64 bit:
http://www.geforce.com/drivers/results/49949
If other drivers needed:
Remember to uninstall the old one before you install the new one.
Try also to check the screen resolution on the screen
set it to factory settings.
But the game resolution could also have been set to high
when this happens you get a black screen.
Good luck
Posted on Nov 02, 2012
  • 20 Answers
SOURCE: will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Posted on Mar 27, 2008
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
sandrew
  • 2961 Answers
SOURCE: input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Posted on Apr 25, 2007
  • 115 Answers
SOURCE: message is input not supported
Might be the VGA cable of Monitor is not connected with CPU or vice versa.Pls check it and re-connect.If still problem is coming then start the system and press F8 continuously still dos screen and choose a option that Enable VGA Mode.after that login through and re-configure the monitor compatible setting by right click on desktop and click on setting select 1024.768 and apply.
Posted on Nov 17, 2009
SOURCE: Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Posted on Dec 31, 2010
No picture with GeForce 210 graphics card
Picture? Are you saying it does not work? Is this a new install? Is it setup/installed correctly? Have you installed the software? Drivers? Need more info.
Mar 20, 2013 | HP Pavilion a1423w PC Desktop
I have a acer x163w 13" monitor and I am trying to play call of duty 2 but keep getting the input not supported. How could I fix this problem so that I may play this game?
Call of Duty 2 Minimum System Requirements
3D hardware accelerator card required - 100% DirectX 9.0c compatible 64MB hardware accelerator video card and the latest drivers*
English version of Microsoft Windows 2000/XP
Pentium IV 1.4GHz or AMD Athlon XP 1700+ processor or higher
256MB RAM (512MB RAM recommended)
100% DirectX 9.0c compatible 16-bit sound card and latest drivers
100% Windows 2000/XP compatible mouse, keyboard and latest drivers
4.0GB of uncompressed free hard disk space (plus 600MB for Windows 2000/XP swap file)
8x speed CD-ROM or 2x DVD-ROM drive
Multi-player Requirements
Internet (TCP/IP) and LAN (TCP/IP) play supported
Internet play requires broadband connection and latest drivers
LAN play requires network interface card and latest drivers
Supported Chipsets
ATI Radeon 8500
ATI Radeon 9000
ATI Radeon 9200
ATI Radeon 9500
ATI Radeon 9600
ATI Radeon 9700
ATI Radeon 9800
ATI Radeon X300
ATI Radeon X550
ATI Radeon X600
ATI Radeon X700
ATI Radeon X800
ATI Radeon X850
nVidia GeForce 2 Ultra
All nVidia GeForce 3/Ti Series
All nVidia GeForce 4/Ti Series
All nVidia GeForce FX Series
All nVidia GeForce 6 Series
**Recommend nVidia GeForce 7 Series or higher
Do your PC support the above hardware requirements?
The most common input no support would be your graphic card is not up to the mark to play the PC games.
Is your graphics card drivers up to date to the latest?
Have you updated your DirectX to the latest version?
Hope it helps.
Apr 17, 2011 | Acer X193W LCD Monitor
Nvidia geforce 6100 nforce 405 if i can enable the nvidia it becomes HIGH FREQUENCY in monitor but if can disable its use properly but i can play the games i want.. how to solve this problem?..
dude its prety easy go to control pannel detect the nvidiacontroler there
go to its properties and reduce the frequency to as of the monitor its better make it 60mhz that normally works
Feb 03, 2010 | AMD Asus A8N-VM Dual-Core nVidia GeForce...
Invalid scan freq.????
Windows 95??
If it was me, I'd install a new Linux distro, then run Wolfenstein on Wine (or PlayOnLinux).
Wolfenstein Supported software PlayOnLinux Run your Windows applications...
Apr 08, 2017 | Cornerstone Professional P1500 Monitor
NVidia Geforce FX 5500 Playing Videos and Games
Seems like your video card just is either a little broken, maybe it overheated a couple of times to much, or it simply isn't fast enough to display all these games.
If I were you and I'd want to play these games, I'd buy a new PC.
For US$500 you've got a PC that can easily run these games on high without any problems.
I'm afraid there's no other way to fix this problem, your PC is just too old.
I hope this helps,
Yannick.
May 29, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
Slow Graphic Acceleration
i play WoW and i recommend you get at least 2Gig memory and with that card you need to run the game in low settings. The 5200 series card is not high end gaming card. If you have pci express slot i highly recommend a 9600GT. But first upgrade to 2Gig RAM
May 12, 2009 | Gigabyte NVIDIA GeForce FX5200 N52 series...
Program won't run, error message says it can't find 3d software.
If the error message says "Cannot find any compatible Direct 3D devices" it means that you do not have a supported video on your system, and that you need to upgrade your video card.
The Recommended and Minimum System Requirements for the are game mentioned below your system has to meet at least the Minimum System Requirements for the game to launch on your system.
Recommended System Requirements:
- 3 GHz Intel Pentium 4 or equivalent processor
- 1GB System Ram
- ATI Radeon X800 series, NVIDIA GeForce 6800 series or higher video card
1.2. Minimum System Requirements
Minimum System Requirements:
- Windows XP
- 512MB System RAM
- 2 GHz Intel Pentium 4 or equivalent processor
- 128MB Direct3D compatible video card with DirectX 9.0c compatible driver
- CD-ROM or DVD-ROM drive
- 4.6GB free hard disk space
- DirectX 9.0c (included)
- DirectX 8.1 compatible sound card
- Microsoft .NET 2.0 Framework for toolset (included)
- Broadband connection for multiplayer online play
- Keyboard, Mouse
1.3. Supported Video Cards
- ATI Radeon X1900 series
- ATI Radeon X1800 series
- ATI Radeon X1600 series
- ATI Radeon X1300 series
- ATI Radeon X850 series
- ATI Radeon X700 series
- ATI Radeon X600 series
- ATI Radeon X300 series
- ATI Radeon 9800 series
- ATI Radeon 9600 series
- ATI Radeon 9500 series
- NVIDIA GeForce 7900 series
- NVIDIA GeForce 7800 series
- NVIDIA GeForce 7600 series
- NVIDIA GeForce 7300 series
- NVIDIA GeForce 6800 series
- NVIDIA GeForce 6600 series
- NVIDIA GeForce 6500 series
- NVIDIA GeForce 6200 series
- NVIDIA GeForce 6100 series
- NVIDIA GeForce FX 5900 series
- NVIDIA GeForce FX 5700 series
- NVIDIA GeForce FX 5600 series
- NVIDIA GeForce FX 5500 series
Oct 28, 2008 | Video Game Consoles & Games
When i try to play the game i get fatal error msg
The error message means that your video card "ATI Visontek Radeon 9250" does not meet the game requirements.
Your video card Pixel Shader Version is 1.4 , and Devil May Cry 4 needs at least Pixel Shader 3.0 or higher support.
To play the game you need to upgrade your video card, to meet the minimum requirements for the game you need a video card like the ATI Radeon X700 or the Nvidia GeForce 6600.
The requirements list for the game as available in the "ReadMe" file for the game Devil May Cry 4 is mentioned below.
System Requirements
Operating System: Microsoft(R) Windows(R) XP *1, Microsoft(R) Windows Vista(TM) *1
-CPU: Intel(R) Pentium(R) 4 processor supporting HT Technology or higher
(Recommended: Intel(R) Core(TM)2 Duo processor or higher)
-Main Memory: Windows(R) XP : at least 512MB (Recommended: at least 1GB)
Windows Vista(TM) : at least 1GB (Recommended: at least 2GB)
-Video Card: DirectX(R)9.0c/Shader3.0 compatible, VRAM256MB,
NVIDIA(R) GeForce(R) 6600 series or higher
*excluding NVIDIA(R) GeForce(R) 7300 series
(Recommended: NVIDIA(R) GeForce(R) 8600 series or higher)
-Sound Card: DirectX(R)9.0c compatible sound cards
-DVD-ROM Drive: DVD9 compatible drive
-Monitor: 640x480 (VGA) or higher (Recommended: 1280x720 or higher)
-Input Devices: Mouse & Keyboard required (Recommended: Xbox 360(R) Controller for Windows(R))
-Hard Disk Space: at least 8GB
Oct 25, 2008 | Capcom Devil May Cry 4
GeForce FX 6800 Graphic... Problem
you should look for updated drivers - www.nvidia.com
If the problem persists, it might suggest a hardware problem.
It is a good idea to test the card in another machine and see if the same problem happens.(maybe in your friends computer ?)
Mar 08, 2008 | XFX GeForce FX 6800 (256 MB) Graphic Card
My AOC 17" CRT monitor displays large veiw on DOS & some PC DOS games where the top portion is displayed at the bottom of the screen.
sounds like you need to run a screen config wizard. If you have a true Nvidia driver you can do this. Otherwise, re-download the driver from the main website http://www.nvidia.com/page/home.html
and it'll work for you
Nov 01, 2007 | AOC CT700G 17" CRT Monitor
Computers & Internet Logo
256 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
