Question about Frigidaire Refrigerators
Frigidaire side bye side la32700897
Water filter had not been changed in 5 years frozeup stop working 2 days later it was working again now stoped
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
YOUR DAMPER INSIDE THE FRIG SIDE IS GETTING STUCK OPEN AND FREEZING THE WATER FILTER AND WILL FREEZE YOU PRODUCE TO YOU WILL NEED TO REPLACE YOUR DAMPER DOOR ASSY INSIDE THE FRIGTOP LEFT CORNER IS WERE IT IS AT
Posted on Nov 02, 2012
Arius
  • 446 Answers
SOURCE: Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
Posted on Nov 27, 2008
  • 92 Answers
SOURCE: 10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Posted on Oct 31, 2007
rpbuice
  • 161 Answers
SOURCE: ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Posted on Jan 19, 2009
SOURCE: Not making ice
the icemaker is not making ice,In the bottom of refridegerator you can see some coils and they are iced over bad.
Posted on Jun 04, 2009
SOURCE: Frigidaire Fridge -- water stopped working
change water filter
Posted on Jul 22, 2009
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Frigidaire Gallery Professional Series - FRS26ZSH My ice and water maker have stopped working. First the water stopped then about 5 days later the ice maker stopped.
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer fan running non-stop+freezer icing up
very likely that either the defrost timer is not working or the defrost heater is not working.
May 04, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Not making ice
The filter does effect somewhat the flow of the water. For some people having problems with ice dispensing it may be as simple as lifting the metal shut off bar up and down. Then check the top of the ice tray to make sure no ice is stuck up there. When you move the metal bar up and down you should see the plastic dispenser that pushes the ice out turning or rotating. Hope this helps.
Dec 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water supply in door will not dispence water
g/e just came out with a heater for this problem i just ordered on the other day i cant remember the part # but call g/e and they can give it to you (the part # )your extended warranty should cover this it isnt a water problem is the ref.and g/e found the problem to late the unit where out in the field although its not a recall they know these units are having problems. i do warranty work every day so I see this as a common problem
Feb 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Refrigerators Logo
467 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
