Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Seagate freeagent drive
Pls let me know how to partition seagate freeagent drive
Regards,
George
  • ajsvoice Jan 14, 2009
    dropped my free agent today it still lights up but windows says it cant read it do to malfunction
  • 728 Answers
Hi George,
The seagate freeagent should be reconigized by windows. The question is are you adding an additional partition or do you want to create a brand new partion. I'm assuming you want to add.
You can add more space to existing primary partitions and logical drives by extending them into adjacent, contiguous unallocated space on the same disk. To extend a basic volume, it must be formatted with the NTFS ile system. You can extend a logical drive within contiguous free space in the extended partition that contains it. If you extend a logical drive beyond the free space available in the extended partition, the extended partition grows to contain the logical drive as long as the extended partition is followed by contiguous unallocated space.
  1. Open Command Prompt.
  2. Type: diskpart
  3. At the DISKPART prompt, type: list volume
    Make note of the number of the basic volume you want to extend.
  4. At the DISKPART prompt, type: select volume n
    Selects the basic volume, n, you want to extend into contiguous, empty space on the same disk.
  5. At the DISKPART prompt, type: extend [size=n] Extends the selected volume by size=n megabytes (MB).
Value Description list volume Displays a list of basic and dynamic volumes on all disks. select volume Selects the specified volume, where n is the volume number, and shifts the focus to it. If no volume is specified, the select command lists the current volume with focus. You can specify the volume by number, drive letter, or mount point path. On a basic disk, selecting a volume also gives the corresponding partition focus. extend Extends the volume with focus into next contiguous unallocated space. For basic volumes, the unallocated space must be on the same disk as, and must follow (be of higher sector offset than) the partition with focus. A dynamic simple or spanned volume can be extended to any empty space on any dynamic disk. Using this command, you can extend an existing volume into newly created space. If the partition was previously formatted with the NTFS file system, the file system is automatically extended to occupy the larger partition. No data loss occurs. If the partition was previously formatted with any file system format other than NTFS, the command fails with no change to the partition.
You cannot extend the current system or boot partitions.
size=n The amount of space, in megabytes (MB), to add to the current partition. If you do not specify a size, the disk is extended to take up all of the next contiguous unallocated space.
Notes
  • To open a command prompt, click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  • You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
  • To extend a basic volume, it must be formatted with the NTFS file system.
  • You can only extend a basic volume onto the same disk.
  • You can only extend a basic volume if it is followed by contiguous unallocated space.
Hope this helps!
Thanks
Mark
Posted on Jan 04, 2009
Seagate freeagent go
It is a better job to extend the partition with 3rd party partition software, you do no to do much effort and then you could achieve the goal, and there are several free partition software that could achieve this goal without data loss like AOMEI Partition Assistant, Gparted live CD and so on, i prefer Aomei, it is much friendly than Gparted and the Diskpart commond.
Sep 19, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
MY HARD DISK TAKING SPACE 35 GB ONLY FOR OPERATING SYSTEM
If you have windows 7, the size should be around 15 GB. More space can be taken up by updates and system restore points created by updates and software/driver installations. You can try running disk cleanup to see if this is the case or not.
Regards,
katharsys_i
Mar 06, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to make partition in a new seagate freeagent Go 320 GB
Here is a link to Microsoft on how to get to and use disk management. I do not know what operating system you are using but disk management has not changed a lot. The link below references XP and if you follow this step by step it will work great.
http://support.microsoft.com/kb/309000
Mar 10, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hi, Need Help Badly, using Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive, Not Formating Properly & may partition table curreped, Taking Long Time To Access, Please Help. With Deep Regards
try to use the following commands
start | run | command |
chkdsk x: /x /f /r (where x: is your seagate hard drive partition)
i think this will solve your problem
Dec 18, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How can I format my Seagate FreeAgent 250 GB USB 2.0 Hard Drive to FAT32? I'm trying to do it all in one partition and FREE! Thanks.
that's easy: 1.
my computer-right click format then when if formated -right click again then format and select FAT32
2. to have one partition download a program (partition magic or acronis in the trial mode and resize the partitions to be just one).
Dec 04, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Trying to format for MAC
I had a similar issue and was able to work around it by partitioning the drive. See this site for information: http://www.kenstone.net/fcp_homepage/partitioning_tiger.html
Overview: Open Disk Utility, Click on the Drive, Click Partition, Choose the number of partitions, and click Apply.
(It's written for video editors, but is applicable in your situation)
Let me know if this helps!
Apr 18, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a freeagent go 500gb portable hard drive. Can I partition?
YES YOU CAN YOU CAN INSTALL AND USE ACRONIS DRIVE PARTITION OR CONTACT SEAGATE TECH SUPPORT AND THEY WILL ASSIST YOU.RICHARDM69
Mar 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
PARTITIONING MY FREEAGENT PRO 500GB
why dont you just make use of win98 bootable disc or smart installer to partition the stuff?
Feb 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
876 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
