Question about Toshiba Televison & Video
Harness wire part number
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Wire harness or even individual plugs with wires are almost never available---if Toshiba as indicated here contact them.
Posted on Nov 02, 2012
I need to find out ? where that I might find an electrical wiring harness or what ever they call it and mounting bracket for 1999 Plymouth Voyager Mini Van.
http://www.installer.com/cars/by_car.php?carid=4627
you will need the universal wiring harness for the make and model of stereo as well
check with supplier
https://www.crutchfield.com/p_120701817/Metra-70-1817-Receiver-Wiring-Harness.html
this site has a checker link to check if it is the right part
It has with infinity or without infinity - Which I do not know what this option is but you might know
this is the car wiring harness model number to search on 70-1817 but you will need the wiring harness adapter for the actual car stereo make and model number as well !
Mar 30, 2017 | Car Audio & Video
I cannot remove the tubing to replace the harness wires from a Kenmore canister vacuum.
One wire of the old harness is connected to the hose and another wire is connected to the switch. Just pull wires and female plug that is attached to the plastic tube pray both side with flat scewdriver
Nov 30, 2014 | Kenmore Vacuums
Clarion cz301e
You can purchase a harness adapter that will plug into the original radios harness. The other end of the adapter harness has loose wires with tinned ends which you connect to the new radio's harness, which as the same colors as the adapter wires.
  • Metra Model: 70-8901 is one adapter that I believe will work.
  • Scosche item Number: 16845632 is another adapter.
  • If you want to buy locally, Best Buy will probably have one or the other. If you want to buy on line, just do a search for the name and model numbers.
Subaru ForesterReceiver Wiring Harness
May 12, 2014 | 04-05 Sg5 Front Lip Ds-Style Urethane
Power went out door locked
Instructions
<:section abp="1260">
    • 1 Unplug your Whirlpool Duet washer from the wall receptacle.
    • 2 Remove the three screws along the bottom front of the washer. Pull the bottom panel from the washer, opening the front of the washer.
    • 3 Reach your arm up through the opening to locate the door latch assemble inside the body of the washer. Grasp the tear-shaped tab with your fingers. Gently pull down on the tab until you hear a click. Pull on the Duet door to open it.
    • 4 Look inside the latch opening in the body of the washer for foreign material. Remove it from the switch with tweezers or needle-nose pliers. Look for any pieces of broken plastic that could indicate the door lock mechanism is broken and needs replacing.
    • 5 Shut the door on the washer and plug it into the wall receptacle. Confirm that the door remains unlocked. Unplug the washer and release the lock on the washer door as before if it fails to remain unlocked.
    • 6 Unplug the Duet washer from the receptacle. Pull the washer from the wall so you can access the rear of the washer.
    • 7 Remove the three screws from the top back of the Duet washer. Lift the top off the washer. Find the central control unit, or CCU, at the back right of the washing machine.
    • 8 Check that all the wiring harnesses plug securely into the CCU. The wiring harness for the door-lock solenoids is the sixth harness from the left of the CCU. The wiring harness for the door-lock main switches is the only black harness connected to the CCU.
    • 9 Remove the round retainer holding the rubber boot gasket from the Duet washer door opening by inserting a flat-head screwdriver beneath the spring on the retainer. Pull forward on the retainer spring to release it from the boot gasket.
    • 10 Pull the rubber boot gasket away from the opening at the switch location to access the door switch assembly. Check the wiring harness on the switch assembly to make sure it is engaged. Snap the gasket back in place, and replace the retainer on the washer.
    • 11 Plug the Duet washer into the wall receptacle. Select a washing cycle and press start. Listen for the door lock to engage. Turn the washer off and listen for the door lock to disengage, or wait 30 seconds and try to open the washer door.
    • 12 Unplug the washer from the wall receptacle. Pull the wiring harness for the door-lock solenoids from the CCU. Number the sets of wires attached to the wiring harness as 3, 2 and 1, from left to right.
    • 13 Set an electrical multimeter to "Ohm X1K." Insert one probe from the multimeter into opening number 3, along with the wire. Insert the remaining probe into opening number 2, along with the wires. The multimeter should read 60 ohms. Leave the probe in opening number 3, and move the remaining probe to opening number 1. The multimeter should read 60 ohms in this position as well. Should you receive any other reading, replace the wiring harness.
    • 14 Reconnect the wiring harness for the door-lock solenoids into the CCU. Plug the Duet washing machine into the wall receptacle. Select a wash cycle on the duet, then press start. Listen for the door lock to engage and immediately unplug the washer from the wall.
    • 15 Leave the wiring harness for the door-lock main switches plugged into the CCU. Number the wires in the harness 5, 4, 2 and 1, from left to right. The middle opening on the wiring harness is empty, so there isn't a third wire.
    • 16 Set the dial on the electrical multimeter to "Ohms X1K." Insert one probe into the opening next to wire 5, and insert the remaining probe into the opening next to wire 4. The meter should read zero ohms.
    • 17 Insert one probe into the opening next to wire number 2, and insert the remaining probe into the opening next to wire 1. The meter should read zero ohms. Replace the wiring harness should you receive any other reading.
Found this on the web . Hope this helps
Mar 30, 2014 | Whirlpool Duet WFW9750WW White Front Load...
I have 2010 Ford Taurus SHO seats. I believe they are 8 or 10 way memory seats. Trying to retrofit for a street rod. Have a few wiring diagrams but not enough. Can't get power to any motors yet. Numb
Problem Solved !!! I traced every wire, Bought manuals, Ended up buying a passenger seat wiring harness and removed driver memory control module plus harness. Installed new passenger harness and it works great ! You need VIN# when ordering part, Order number is slightly different then number on wire harness but when it came in numbers matched. AU5T 14D230 J4CP7
Nov 15, 2013 | 2010 Ford Taurus SHO
Need wiring diagram fo 1994 nissan quest gxe premium stereo
A picture requires an installation, which is what you are doing. You should invest in a vehicle specific wiring harness. The wiring colors match for the connection and said harness then plug into the factory harness. If the factory harness no longer exists then you need the wiring diagram for the vehicle. You mention the vehicle has a premium stereo, the Metra part number is 70-5510. It's for an amplified system.
Aug 11, 2012 | Nissan Vehicle Parts & Accessories
Need to find a wiring harness
I would need further information: What most people do not realize is that a wiring harness is not a "one size fits all" thing. There are two harnesses that you may need.
To remove your factory car stereo and install a new aftermarket car stereo there are wiring harnesses for most cars that will plug right in to the wires from your old factory radio.
For that, you will need to buy the correct wiring harness for the year and make of your vehicle. Say, for example: 1987 Toyota.
Then there is a wiring harness for the specific car stereo. You will need the make and model number of the unit itself. Example: JVC model KD-AVX77.
Jul 24, 2009 | Car Audio & Video
Im puttin a new head unit with a different wire harness, i know what all the wires are on that wire harness, but with the 92 accord stereo wire harness i need to know which wires are speaker, remote, power...
You can buy a cheap harness from the local parts store for your Honda made specifically to put in aftermarket head units. Since you know the pin outs on your head unit, you can wire it up quickly uning this harness and it will plug directly into the factory Honda harness. Go to Scosche dot com part lookup for your number - I think the wiring schematic is on the outside of the package, too.
Apr 14, 2009 | 1992 Honda Accord
Televison & Video Logo
11 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
