Question about Brother Office Equipment & Supplies
How do i perform a routine maintenence on my mf5440cn printer?
What does the wrench symbol mean
Maintenance count reminder to perform routine maintenance by technician ..
Jun 19, 2014 | Toshiba e-Studio120 Copier
Routine maintenance required needs to be reset
Routine maintenance is required ie fuser, charge roller, transfer roller & pickup rolls need to be replaced.
Apr 02, 2014 | Lexmark T650n Laser Printer
Line on paper when i print
Please allow it to perform self maintenance after a power cycle, which may include calibration, cleaning and aligning of the printing heads. Otherwise, you may be able to find those options within the printer driver or print dialogs in your pc to manually force a maintenance routine.
Hope this helps.
Jan 08, 2014 | Brother MFC 8500 All-In-One Laser Printer
Does brother mfc-j4410dw make routine cleans? How can i install a ink dispenser?
I had a Brother MFC that would startle me when it starts to perform its maintenance work. I never bothered asking myself where the ink went.
Jan 02, 2014 | Brother MFC-J415W Multifunction Inkjet...
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
Why does my printer say "Color ink cartridge not recognized-Replace color ink cartdridge" when it is almost a new cartridge and I just printed with it last night and it did fine?
remove the cartridge and clean it with alcohol ... reinstall it. if your printer software offers a maintenance routine, perform the maintenance.
May 01, 2010 | Office Equipment & Supplies
What does perform service message mean?
This is a oil change reminder. Nothing fancy about, when you get your oil change go into the menu and click reset counter and it will go off. If there was something wrong with your car the check engine light would come on.
Apr 15, 2010 | 2002 Jeep Grand Cherokee
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Will not print
I have the same error message “Check the Troubleshooting and Routine Maintenance Chapter in User's Guide" I called customer service for "BROTHER 1-800-284-4329 USA; 1-877-BROTHER for CANADA. The Tech’s and I performed a series of diagnostic test, via the phone but were unable to solve the problem... Brother seem to believe that I have a defected printer head, Brother referred me to a local authorize service agent for Brother. I do have my User's Guide and there is no additional information that I was able to use to resolve this problem. HOW EVER, I am able to get the machine to print by opening the cover and close it as if I had installed ink, or removed a paper jam “SIMPLY OPEN AND CLOSE THE COVER”. I also vacuumed and blew the insides and the outside buttons of the machine with forced air from my vacuum, after all that I still have the same problem. My solution...buy a new machine mine is 32 months old and I probably have ran 15k or more print, fax, and copy jobs.
Some times we need to know when to move on, TIME IS MONEY AND TIME WASTED IS UN-REFUNDABLE.
GOOD LUCK
TG/Ks
Jan 22, 2008 | Brother MFC-3240C All-In-One InkJet...
88 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
