Can a damp basement ruin a washing machine?
My house is a rental and the floors and walls in the basement are damp year round, especially near the washer and dryer hook ups. Sometimes little rivers of water can even be seen. The washer and dryer we owned before moving in have both broke since living here. Now the washer that was with the property has broken. 3 machines broken in 3 years makes me nervous to purchase another of my own. Can the dampness be doing this or just bad luck?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
YES IT CAN
Posted on Nov 02, 2012
  • susanhank
    susanhank Nov 02, 2012
    Can you tell me how it damages it, so I can bring this up with my land lord? Thanks!
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Posted on Sep 25, 2009
vostendorp
  • 347 Answers
SOURCE: While finishing a load of laundry, during the
Yes I do know unfortunely the basket support broke. This support is mounted on to the back of the basket and goes through the rear bearing and the back half of the outer tub. This is a very extensive repair .the unit has to be totally disassembled ,if it only broke the support it is about 100.00 , but if the rear tub bearing is also damaged you may consider replacing the unit with a new one either way this is an expensive and extensive repair...
Posted on Sep 17, 2010
My washing machine when it's changing cycles and water is going into the wall it overflows onto the floor how can I fix it
Sounds like you have might have a clogged waste line. There should be a "P" trap at the bottom of the pipe that your washing machine discharges into. Try cleaning the pipe with a Drain Bladder or small drain snake you can rent these at your local tool rental store.
Jul 30, 2017 | Washing Machines
Injector assembly spitting water
IT is most likely misaligned.
Nov 24, 2013 | Maytag Washing Machines
I have noticed blue mold in my basement coming from behind the area that has wood paneling, but also around the entire edge of the floor even where the walls are concrete (both interior and exterior...
This mold is from dampness in the basement.
Often this is a result of no vapor barrier installed when the insulation is put into the walls. Moisture is allowed to seep through the walls and gets into anything, even concrete.
The other problem may be from a lack of weeping tiles outside the house.
When the contractor formed the foundation walls, he was supposed to install weeping tiles to keep moisture out from outside.
Most older houses don't have this, and I'm seeing it more and more.
I would advise contacting a general contractor and getting some advice from them. You may have to have weeping tiles installed, which consists of tearing up the ground around the foundation to do so.
Then you may have to remove the flooring and wall panels as well as the drywall to install a vapor barrier.
Good luck.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Sep 22, 2011 | Computers & Internet
I have ceramic (terra cotta) block walls in my basement (house was built around 1920. The blocks are ridgid and were not laid very evenly, although the walls are sound. Plastering is an option, but with...
My house is of similar age and construction. I built a nice TV room in the basement several years ago. My method was the same as the way interior walls are built in new construction. I nailed a 2x4 to the ceiling near the wall. I nailed another 2x4 (pressure treated) to the concrete floor directly below the 2x4 on the ceiling. Then I toe-nailed vertical studs in place. For the studs I used 2x3's since this allowed me to get a nice flat plane on the front surface while allowing an inch of space on the back for irregularities of the block wall. I then covered the studs with water resistant drywall. The results were excellent and have held up very well. I also use a dehumidifier, since my basement was somewhat damp. I built the dehumidifier into a cabinet so that it draws air from the space between the block wall and the 2x3 wall. I don't need to run the dehumidifier in the winter. For the interior walls separating the TV room from the rest of the basement (furnace and workshop area) I used 2x4s for the studs, but the 2x4 along the top and bottom were just like the first wall I described. And by the way, in order to nail the pressure treated 2x4 to the floor, I used a power-nailer that uses charges that look like 22 caliber gun blanks. This seems spooky, and is wicked loud (use earplugs and safety glasses!), but it is inexpensive and very effective. The nails don't have to resist pulling out, they only have to resist being slid around, since the wall stud holds the pressure treated 2x4 against the floor. Good luck!
Apr 07, 2011 | Drills
Connecting to wireless from my basement!
you need to add a repeater or signal booster for reciving signal in basement from uper floor.
My expierince is that whatever roueter you buy doenst matter it will not work properly if you are using wirless on 2 diffrent floors. on a same floor it can work smoothly even having walls.
Oct 02, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Badly shakes on spin cycle. Smooth on extra high speed only.
That is what these are bad for.... they are very hard to control especially if you are on a second floor or above a basement or something.... thats why i personally dislike them...
Apr 26, 2009 | LG Washing Machines
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Legacy leaked on floor and subsequently ruined gararge ceiling. I put a wash in yesterday, filled it shut it off and left it soaking. I returned home from my errands three hours later to an 3/4 empty SS...
Its most likely the tub seal at the bottom, check and see if the area inside is wet in the middle. You will need to remove the outer panels to do this. It doesn't sound like anything else if the water was left to sit so a replacement of the seals around the center shaft should fix this problem. Let me know if you have any questions about doing this and I would be happy to help.
Jun 04, 2008 | Maytag Legacy Series Top Load Washer
Rocking and VIbrating
As long as you have it on the second floor there really isnt anything you can do to fix it anything you do will probably make it worse there is only one washer i know of that is front load and acts decent on the second story and thats the new samsung with the roller bearings. Sorry to tell you but u will probably end up moving it to the basement
Jul 14, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
