Question about Panasonic TH-42PZ700U 42 in. Plasma Television
I have a 42" Panasonic plasm. The power doesn't go on just a flashing red light that blinks 7 times. Whats my problem? Is it costly?
  • 1 more comment
  • yonx99 Jan 04, 2009
    when you say "volts from the power supply are normal" are you indicating from the electric in my house or some else?
    Thanks for taking the time .... yonx99
  • raisedinaubu Jan 18, 2009
    My plasma tv is not working. The red power light blinks 10 times and that is all. Please help.
  • vladyka Jan 28, 2009
    Same problem! I was watching TV and then the TV simply shut down, and the red light in the lower left corner started blinking 7 times. The TV is just out of warranty, of course, so it will cost quite a bit to fix. It will also be a real pain to repair, since this is one heavy TV. Right before the Superbowl, as well. I remember not too long ago when TVs never broke! No more Panasonic products for us, ever!!!
Have you tried manually changing the channel from the set itself? I have a sanyo that goes into "sleep" mode and I find if I change the channel manually, not w/ the remote, it will come back on.
Posted on Jan 04, 2009
    Sergeant:
  • 378 Answers
The 7 blinks means that the SC scan drive board might need to be replace but only after checking the voltages from the power supply. If the voltages from the power supply are normal, then proceed to replace the SC scan board.
Click here to find the board you need.
and about the cost is near to  $170. for anything else let me know. thanks.
PANASONIC TV P42ST30B JUST WENT OFF NOW RED LIGHT FLASHES 7 TIMES, STOPS, THEN FLASHES 7 TIMES AND SO ON
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 10, 2015 | Panasonic TX-P42ST30B 42" 3D Plasma TV...
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My Panasonic TH-42PZ700U 42in. TV doesn't turn on anymore. The red power light blinks 7 times. I hold down the power button until it stops blinking. When I let go of the button, the red power light stays...
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
Mar 04, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic Plasma TV - Model # TH42PX77U does not turn on and red light next to power button blinks 7 times - what does this mean? What would be a good estimate for a repair - parts and labor?
This is a difficult question to answer completely. 7 blinks indicates that one of the C boads has failed. however, there are several an SC,SD, SS and SU.
The procedure is to disconnect each of there boards until the blinking is eliminated. The labor charge is usually around 200.00 and the cost of whichever board is bad. Hope this helps.
Oct 21, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Red Blinking Light/No Picture
7 blinks? Many have replaced caps on the SMPS board, with success: 2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 1 00μF 25v. Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Jul 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
225 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
