Question about Coleman Heating & Cooling
Evcon furnace DGAT056BDF igniter switch
How much & where do u find it inside the furnance
    Top Expert:
  • Coleman Master
  • 5,706 Answers
Follow wire from control board
Posted on Sep 11, 2017
Buffalo12980
  • 625 Answers
SOURCE: How to install an igniter?
if the heater uses a hot surface igniter its a simple matter of unscrewing the igniter and replacing it with another unit. if it is a spark ignition, the spark wire is a heavy insulated wire that goes to the gap. check out white-rodgers for a replacement. if your furnace uses a purge mode get a purge cycle programmable igniter.
Posted on Nov 15, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: 1985 evcon forced air furnace no ac
Most likely your flame rod is either dirty, bad or the flame is not hitting it. It is located either to the far left or far right of the burner box. It has one wire going to it and looks like a small stick pointing into the flame. Clean it with a long tooth brush. Inspect the wire where it attaches to both the rod and the control module. Inspect the flame as it starts and see if the flame reaches it within 2 to 3 seconds from first flame. If not, you may have debris clogging the flame tray not allowing the flame to pass. If this is beyond your mechanical skills (no offence) contact your gas technician.
Posted on May 30, 2008
  • 70 Answers
SOURCE: i have a coleman/evcon electric
Have you tried to replace pressure switch for the combustion air. If your not sure where to find it if you pull the front panels off follow the flue pipe down to combustion chamber the combustion fan motor is either inside the flue pipe or out side of it not sure on the one you have but you should see two plastic tubes that connect to a barb onto the topside of the fan and one on the bottom they both should go back to the pressure switch. i hope this helps you if you have any more question or if this doesnt fix the problem just reply back to this message . Make sure fan is working when furnace starts up. It should be the first thing that comes on when there is a call for heat
Posted on Jan 21, 2009
  • 189 Answers
SOURCE: Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Posted on Apr 10, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Burnham Boiler, no constant ignition.
Is there a pressure switch you can jump to see if it is defective? Is the inducer fan blowing out exhaust? You could also have a dirty pilot.
Posted on Dec 01, 2009
When i turn up the thermostat the furnance doesnt come on
have you replaced the board? Need more info. Have 120 volt power? check small fuse in board. Make sure blower door is closed, it has a cutoff switch.
Sep 29, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman electric furnace
You don't say whether you replaced the blower but that could be the next thing to check
Jul 23, 2013 | Heating & Cooling
Evcon furnace pilot light keeps shutting off
First check flame sencor is clean , check pilot is not blocked may need cleaning out , check hoses to pressure not split of blocked , jump out pressure switch see if it lights then , check air filter is not blocked .
Mar 16, 2013 | Heating & Cooling
My furnance is acting up you turn it on it clicks on then lights the flame gets big then seconds later the flames go out and the blower kicks on what could be the problem ive had several people look at it...
If the fan takes too long to come on, the high temp limit may be opening. Could be a defective limit, hard to say without more info. Another possibility is a mis-adjusted heat anticipator. A normal setting would be around .45 amp. The heat anticipator is inside the cover of the thermostat (older, analog style). Good luck.
Nov 28, 2009 | Tools & Hardware - Others
Heating & Cooling Logo
186 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
