Question about Panasonic PT-47WX49 47" Rear Projection Television
Corner convergence for panasonic pt51hx40c projection tv
I do not have the service codes to do a 9 point convergence setting on my rear projection tv??? I heard that there is a numeric code you can activate on your remote control device that will get you in to a more acvanced convergence settings foor my tv....
  • kent ggg Mar 06, 2009
    i cant get mine set either except on panasonic PT-51HX40c
    the line will be lined up at the top of the screen and not at the bottom...so..i will line it up and the bottom then it wont be lined up at the top...lol.. same thing side to side
  • Panasonic Master
  • 5,138 Answers
Yes there is a Service Code you need in order to set convergence and on this set it is not easy to enter! 1) Switch Antenna to cable (2) Set Sleep Timer to 30 mins,Exit menu Enter ch 124 (3) Now Press vol- on front of TV / A red CHK should appear on screen / NOW enter menu and turn sleep timer off / Exit again,now Press Power untill you see 0V00 press ch up untill you see 0V1 Then Press vol+ you should now have convergence Pattern on screen. To adjust use (ch- ch+ and vol- vol+) (cursor) moves to where you want to adjust (mute) locks place you want to adjust RTune changes R-G-B when done make sure you Save adjustments.
Posted on Jan 04, 2009
Colors are separated, double vision in lower right corner.
Oh, yea - another misaligned projection TV. All rear projection TV's seem to eventually get this disease.
Fix: perform a "convergence," which will converge all 3 color projectors to the same point.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Dec 11, 2010 | Sony KP-53XBR200 53" Rear Projection...
Convergence on my panasonic pt47wx53g is out of whack. tried setting to default and tried the convergence steps in book. neither worked. red is especially bad. everything looks to have 2 heads 4 eyes...
Did you try the service menu convergence options or are you talking about the basic conergence steps in the manual?
I have had this TV for going on 9 years and would be happy to walk you through the steps.
Jan 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic hdtv projection colors will not line up
If only minor convergence issues, the setup menu has user controls for 9-point convergence. If it's major misalignment in just one color, you may have a blown convergence amplifier chip. Big bucks repair, unfortunately. Chipsare about 30-40 dollars apiece but labor will kill you if they'll even fix it on-site. Most try to order $700+ board which is no longer available. Teh they send yours out for -10 weeks at similar prices.
Jun 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic hd projection with conver. problems
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 24, 2009 | Panasonic PT-56HX41 56" Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Picture quality
Have you tried adjusting the convergence yourself?
Oct 15, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Sony KP-48S65 48 in. Rear Projection: fine tune convergence
you will have to go in the service mode. be careful as you could damage the tv if wrong settings are changed. with the tv off push on the remote display 5 vol+ power. now hit the 1 button until you see pje fdis on the upper left. now push the 9 button to enter convergence. you should now have a cursor on the screen. usr the 3 button to switch colors. use the directional pad on remote to move the cursor and the enter button in the center of dir pad to select or deselct a point in the screen. push muting and then enter to save convergence. now restart the tv and all done
Sep 19, 2007 | Sony KP-48S65 48" Rear Projection...
Panasonic PT51HX41E
you need remote control that came with tv ,there is a service code menu for techicians only - setting convergence on these sets are not easy.you Must Know what you are doing other wise you can shut set down with bigger problems.Call a repair shop if your not sure.I have service codes but ,i will not tell someone these codes unless they do know How to set convergence.
Oct 23, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
231 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
