Question about Panasonic KX-TG1062M DECT 6.0 Expandable Dual-Handset Corded / Cordless Phone System with Caller ID and Answering System, KX-TG1062-M,KXTG1062M,KXTG1062-M,KX-TG1061
Constant busy signal when I call a certain number
Keep getting a busy signal when I dial a certain extension. All others are working fine. Any ideas or suggestions on whats going on?
Hello Teri...
AFTER you have ASSURED you do not have any CALL DEFLECTIONS, call-forwarding or DO-NOT-DISTURB
features invoked...
Hang up the "extension" you are DIALING from...
Go to a different phone and re-dial the BUSY NUMBER
that has you so perplexed...
Expect the phone you were on to be ringing...
ELSE
you have a FALSE BUSY condition on
your EXCHANGE
Carnac the Magnificent
Apr 06, 2017 | Lands Phones
Panasonic voice mail works fine except when our line is busy callers get the busy signal and are unable to leave a voice message
Yes - Afraid that is the case, certainly in the uk.
Phone will only accept a message if phone is not in use / not answered.
You do get notified that there is a call waiting so you can either switch to their call and ask them to call back.
Or when you have finished call - their number will show as last caller and you can call them back.
Nov 02, 2016 | Panasonic Lands Phones
When my iWork's is paired with my iPhone 6 splus it plays music for a bit then starts playing a busy signal then plays music for a few seconds then the busy signal again
iPhone 6 not working with hands-free on a Toyot... ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 20, 2014 - I received the iPhone 6 today and registered the device on my Toyota... The iPhone 6 paired with the audio system, but whenever the phone receives a ... I also notice sometimes the vehicle shows 0 signal strength, when in ...Missing: iwork's ‎splus ‎random ‎busy
iPhone 6 dropping WiFi constantly ' Apple Support Communities
Apple Inc.Sep 20, 2014 - Got my iPhone 6 today and it keeps dropping my WiFi signal in my ....kick of wi fi constantly worse part is I was busy listening to music app last ...Missing: iwork's ‎paired ‎splus
Community: Using iPhone ' Apple Support Communities
Dec 25, 2015 | Cell Phones
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Has this constant busy signal just started or has it come recently? If you've got a space receiver/handset use it to replace what you've got connected at present. If fault persists then it's not the unit that's at fault but the line's faulty and needs reporting to the service provider. If the fault went away when you changed the unit then you know that the problem lies with the handset/receiver or whatever you call it. Decide what to do in this case-probably get a better handset.
May 06, 2015 | Lands Phones
Can the cordless phone KX-TG7642 be used without a cell phone?
Had the same busy signal constantly on my KX-TG7642. Needed to change the setting under cell line only to off as it was on. It's in the manual.....Hope this helps.
Jan 03, 2012 | Panasonic Mustang Lands Phones
I cant reach a certain phone number. It is a 609 area code number. All I get is a busy signal. any idea why?
Does this happen from another phone, if it does than it means that either the line is busy, or they could have blocked the number.
Feb 15, 2011 | Computers & Internet
Uh049sx." BUSY" light on all the time. wont recieve
Contact a service center in your own country.
turn the squelch button down.
Oct 19, 2008 | Radio Communications
Busy signal
Voice mail is probably got a blown hard drive and we fix that. or it could just use a reset. Turn off and back on or check out your manuals and guides here
http://guides.idacomusa.com/
May 22, 2008 | Toshiba DKT-2020-SD telephone
Panasonic KX-TG1062M DECT 6.0 Expandable Dual-Handset Corded / Cordless Phone System with Caller ID and Answering System, KX-TG1062-M,KXTG1062M,KXTG1062-M,KX-TG1061 Logo
24 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
