Question about AudioBahn DUB1000 Car Subwoofer
My voice coils are burnt on my dub 1000, can i rebuild the speakers, and where do i get the parts
I can hear pieces inside, cones feel kinda ruogh
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
No have to buy new
Posted on Nov 02, 2012
2 Suggested Answers
  • 108 Answers
SOURCE: i think voice coil is
The voice coil can be properly checked with a voltmeter. Disconnect the speaker and use the OHM setting on the meter to check to see if it measures around 4 ohms. Is this speaker a subwoofer? Some subwoofers will be rated at 2 ohms. Either way, any speaker should have a sticker or stamp on it telling what the impedence is. Typically, most speakers will be either a 2ohm or 4ohm measurement. If the coil is bad, you will either get no reading or one that is much higher than the 2ohm or 4ohm. Hope this information is helpful.
Posted on Sep 19, 2008
My jbl eon 15 g2 smell like burnt and everything works but the big speaker
The voice coil in the big speaker could have been damaged if driven to loud. See if the burnt smell is strongest near the center of the big speaker. If the voice coil is fried, you may be able to still find a replacement as there is a part number for the voice coil (V/C Assy, EON-G2220-27005-00) and the cone (EONG2
Cone Repl. C2REON15P-2)
Jan 18, 2015 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Speaker vibration
Check for loose or broken parts. .Check speaker cone for damage and check voice coil for burnt wires with an ohm meter
Apr 24, 2013 | Mission Audio Players & Recorders
My speaker isn't working properly.
Hello sir, hi there, usually speakers are replaceable if its not working, if the value of your speakers are quite high, you may need to rewind the voice coil, or find a replacement voice coil for it, much better you need to replace the entire unit. Here are some test to confirm if your speakers are busted. 1. get a double A battery. 2. connect the negative terminal to the negative of the battery using a black wire. 3. connect the positive terminal of the speaker to the positive of the battery intermittently with a red wire. 4. you should hear clicks. no clicks it's busted. replace the driver.
test for voice coil free flow. press gently the cone, and feel the free movement, if you feel friction or scratches, replace the driver.
Nov 06, 2010 | Audio Players & Recorders
My subwoofer keeps making a clunking noise...How do I correct this problem?
The clunking noise could be the voice coil maxing out hitting its stop or a warped voice coil. How much power is going to the subwoofer. If it only happens when the high volume setting it and not at medium volume the subwoofer may not be able to handle the power. With your hand gently push the speaker cone back and release the cone so it can return to its rest state several times. Do you hear a scratching sound or feel any resistance? If you do your voice coil is damaged if not from physical means it could be from the voice coil overheating. If it is OK shake and rap on the subwoofer box and try to identify any loose parts which could be making noise.
Aug 13, 2010 | Denon Audio Players & Recorders
My mtx 10' sub is jammed, is there anyway i can fix it by myself without costing a fortune, i believe its a burnt coil
The voice coil has overheated. If you feel confident, you might be able to purchase a re-cone kit and do it yourself. But it's an art, so to speak. Contact the manufacturer, or a speaker re-coning service.
Apr 10, 2010 | Car Audio & Video
It sounds like one of the voice coils is loose how do i get the plastic piece that connects to the spider out thanks
The "plastic piece" doesn't give any of us much to go on... there are many parts connected to the spider. Examples are the cone edge flexure and the centering flexure near the voice coil.
Most f these are held with adhesive.
If a voice coil is loose, it is undoubtedly damaged beyond repair. They rub the pole pieces and wear insulation off and short out blowing the amplifier.
Best to take it for re-coning or read up how to do it. Then you need to get a kit of the materials. There are adhesives, solvents, and new voice coil, centering flexure piece and usually the cover.
Feb 23, 2010 | Jl Audio 12W3v3-4 Car Subwoofer
Woofer seems to be shot, you can still hear the tweeter...how can i figure it out without spending a ton
take it out, check the impedance, push on it and move the cone up and down. is it scratchy? burnt voice coil. check the crossover
Oct 28, 2009 | Boston Acoustics CR6 Speaker
Celestion g12l
I think that one reason for a speaker to rub is due to over heating of the voice coil. This happens when power is applied to the speaker that is greater than the speaker is capable of handling. A second cause could be that the suspension and or cone is damaged or degraded causing the coil to be tilted or off center. In either case nothing short of rebuilding the speaker can be done to repair the speaker. Rebuilding would involve removing the cone and voice coil and replacing with new items. If you were talented you might be able to repair the existing cone or voice coil but the results could be iffy.
Sep 08, 2008 | Celestion 20i Speaker
Voice coils
Hello. I do speaker reconing and amp rebuilds for a living and the L7's often suffer from tinsel leed wire breakage which can cause "poping" and "screaching" noises in the sub in various cone positions. You need to remove the sub and push straight down on the cone repeatly and determine if you can feel or hear crunching noises to make sure the voice coil and/or spider are not damaged. A faulty leed wire can usually be identified by a dark spot or obvious breakage. All of the L5 and L7 models can be successfully repaired as long as they are the older models that have a center cap in the cone. The newer capless models will have to have an upper brace cap glued to all of the cone's fingers and will have a rather ugly appearance. Leed wire overhauls usually run around $30.00 for the older models. Voice coil and spider overhauls run around $90.00.
Dec 12, 2007 | Kicker 02S10L74 Car Subwoofer
AudioBahn DUB1000 Car Subwoofer Logo
27 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
