Sound board on RCA 42 inch TV doesn't work
  • 127 Answers
Do you know if there is voltage?The voltage came from the power suply line.Are you in the mute by accident?
Posted on Nov 02, 2012
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
  • 718 Answers
SOURCE: have a 42 in rca lcd tv ,hsound but no picture
IF the set is under warranty, you should return it.
Do this to see if your set is "sending" the image to the LCD panel.
1) What the set on take a bright flashlight and press it against the screen.
2) Look for the "image" moving around the edge of the flashlight.
3) If you see the "image" then the problem is in the inverter/CCLT or the power to it.
4) If you do not see the "image", you should look at the LCD controller(TCON) for the problem.
Posted on Feb 25, 2009
nicknovikov
  • 100 Answers
SOURCE: how much do amain board cost on a 42 inch vizio tv
shopjimmy.com.check this site.
Posted on Oct 05, 2009
  • 8457 Answers
SOURCE: 42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Posted on Dec 05, 2009
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
My RCA 42 inch TV turns on but I see nothing but different color lines on the screen and no sound.
Lines on the screen usually is a problem with LVDS board, panel or the ribbon cable to the panel. Set should have audio though. the main board processes both audio and video but will not produce colored lines.
Feb 03, 2015 | RCA L42WD250 42 in. LCD HDTV
There are two cicuit boards on the 42 inch lg tv which one should i try to replace first this is the tv with the split screen problem with no sound
When vieing it from behind the right one with the hdmi and the rca plugs is the one to try first but if you could say more about your problem before purchasing any of the boards I could be more usefull
Aug 13, 2014 | LG 42LG50 42 in. LCD HDTV
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
I have a 52 RCA flat screen that the sound works but the pic doesn't. I can hear a clicking sound and then the power button light starts flashing
This RCA projection tv model have known to have many parts of capacitors components are dying and dead on the tv power supply board.That the board section where the tv power a/c cord plug into it.U have all the tools and can do bsaic soldering work too?Yes,try website like Tvrepairworld.com to buy the capacitors compponents set they put together and replaced all these capacitors parts on the tv power supply board section,will solved this problems.
Jul 06, 2011 | RCA HD52W56 52" Rear Projection HDTV
I have a 42 inch rca tv model WB22YX5 componet inputs dont work
Sometimes, these inputs get damaged by ESD, or stray voltages, and become damaged. You may just need to give the set a reset, unplug an leave for 5 mins or so, and try again, if still no go, see if there is anything, in the troubleshooting procedures, that can help. It may just be a board replacement, If you decide, to get it repaired, please first contact RCA head office, and ask for a referral, to an authorised service center.
http://www.scribd.com/doc/7581822/RCA-Chssis-CTC-175176177186187-TV-Training-Manual
May 05, 2010 | RCA L46WD22 Television
I have a 42 inch sharp aquos and the volume doesnt work on the tv or satellite remote, what is the problem
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Dec 18, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
My Lg 42lc7d 42 inch flatscreen tv has no sound
1- check all the cables that are hooked up to the TV 2- try to get audio to and external speakers or home theater (to check the sound card). 3- if the step # 2 don't work either you have a bad sound board on your TV. 4- opn the TV try t get the part # of the board, and replace it
Nov 11, 2009 | LG 42LC7D-UB Television
Rca 42 in lcd it shuts off 5 sec after being turned on
This could be a power supply problem, these tv's use a series of switching mode power supplies usually mounted in the same circuit board , the light flashing is an indicator that this is the problem, but these boards are expensive so you may want to get the tv looked at before anything else. You do not mention if the sound remains in your description of the symptom, but just in case it does then a back light inverter could be at fault. hope this helps. thanks for leaving you feed back.
Aug 27, 2009 | RCA L42WD22 42 in. LCD Television
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
