Question about Toshiba Computers & Internet
How can i exit safe mode on my toshiba laptop
I tried recovery and held down the f8 button and it did not work
  • Toshiba Master
  • 27,725 Answers
Click the "Start" button.
Type "System Configuration" (without quotes) in the search box and select "System Configuration" from the search results.
This will open Microsoft's System Configuration utility.
Click the "Boot" tab.
Clear the "Safe Boot" check box under "Boot Options."
Using the Windows Boot Menu
Turn on your computer.
Press the "F8" key repeatedly immediately after the BIOS screen appears.
The BIOS screen typically displays the logo of the computer manufacturer.
Select "Start Windows Normally" from the boot menu and press "Enter" to proceed.
or
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Posted on Nov 05, 2012
My Toshiba satalite CD5308 laptop system recovery, froze n at 50% of did not complete. Norton has error reading and has stop my internet access.. helpp
restart in safe mode f8 key tap a couple times to enter safe mode and delete norton bs security.then restart pc as normal then do recovery. How To Start your Windows 7 computer in Safe Mode TOSHIBA FORUMS
the link is not just for windows 7 its for all toshiba laptops.
May 26, 2016 | Toshiba Computers & Internet
Startup Repair cannot repair this computer automatically
Try booting into the Safe Mode and check if the issue persists.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words Safe Mode appear in the corners of your monitor to identify which Windows mode you're using.
1. Restart your computer. Click the Start button, click the arrow next to the Shut Down button, and then click Restart.
2. Do one of the following:
· If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
· If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press Enter.
4. Log on to your computer with a user account that has administrator rights.
When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor. To exit safe mode, restart your computer and let Windows start normally.
To know more information on how to boot into Safe mode visit the following link:
Start your computer in safe mode
http://windows.microsoft.com/en-us/windows7/Start-your-computer-in-safe-mode
Method 2: Also scan the Computer for error using chkdsk command in the Command Prompt from the System Recovery Options Menu.
To open the System Recovery Options menu on your computer
1.Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button.
2.Do one of the following:
•If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
•If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
3.On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. (If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.)
4.Select a keyboard layout, and then click Next.
5.On the System Recovery Options menu, click a tool(Command Prompt) to open it.
6. At the Command Prompt, type: chkdsk /r . Press Enter.
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them.
Apr 03, 2014 | Microsoft Computers & Internet
I have a toshiba satellite l655d-s5093 with windows 7 and it shows pxe-mof exiting intel pxe rom... no bootable device -- insert boot disk and press any key. any help to restore my computer? Thanks
Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally.
IF THAT FAILS, try F-8 during pre boot, try to get to safe mode, or F12 to enter restore /recovery. After each try cold start, remove battery during this process.
Nov 09, 2012 | Toshiba Satellite L655D-S5093 Laptop
How can i get out of safe mode on my toshiba laptop
Hello you just have to restart or reboot.
When windows starts again you probably get a question about how you will boot. Just select start windows normaly.
Thats it.
Why did you have to start in safe mode ??
If virus install and run these to programs
http://www.malwarebytes.org/
http://www.superantispyware.com/download.html
Good luck
Nov 02, 2012 | Toshiba Computers & Internet
I need to findout if there is a link to to restore my laptop without a recovery disk because i didnt get one when i bought it
Start the computer in safe mode and run System Restore:
Click the Start button Picture of the Start button, click the arrow next to Shut Down, and then click Restart.
You must press F8 before the Windows logo appears. If the Windows logo appears, try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
On the Advanced Boot Options screen, use the arrow keys to highlight Safe Mode, and then press Enter.
Log on to your computer with a user account that has administrator rights. When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor.
Click the Start button Picture of the Start button, type "system restore" in the search box, click System Restore, and then click Next. Administrator permission required If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Choose a restore point when your PC worked as expected, click Next, and then click Finish.
Use system utility software like RegInOut after restarting windows normally. It will repair corrupt registry and windows files.
Jan 03, 2012 | Toshiba Satellite L455D-S5976 Notebook
Ok i have a toshiba laptop with windows 7 its a sattelite L455D-S5976 i need to find a link to restore it i didnt get a recovery disk when i bought it
Jan 03, 2012 | Computers & Internet
Toshiba satellite L300 black screen. Tried the 0 key and it only goes 1/3. thinking booing/registry corrupt. No recovery disk or software came with my laptop. O/S is Vista I have data and photos that...
Yes everything will be wiped out, once you do the recovery. It will reinstall the factory settings.
You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, then try to boot from safemode. Tap F8 upon booting up to enter the advance boot option. Select safe mode, save your files once loaded in safe mode. You may first try the system restore from , go to start/all programs/accessories/system tools/system restore, select the previous date the laptop was working fine. If this will not work then the last resolution is the recovery.
Hope this helps.
Mar 22, 2011 | Toshiba Satellite Pro L300 Notebook
I have a toshiba laptop & half the keys on the keyboard won't work
Try to go first to Safe Mode.
Bring up the "Start" menu. Select the "Shut Down" option and then click "Restart."
Wait for the Toshiba Satellite A105 laptop to begin its restart procedure. Press the "F8" key at regular intervals (every 3-4 seconds) when the Toshiba logo pops up on the screen.
Continue tapping the "F8" button until the advanced Windows options menu appears. Use the down arrow key to scroll through the list of advanced Windows options.
Highlight the option labeled "Safe Mode." Press the "Enter" key and wait for the operating system to load in safe mode.
On Safe Mode try to use the keys that are not working if it's woking it's a software problem and you need to have a System Restore for the laptop.
If it's still not working go to BIOS Settings of the laptop try to reset it to default settings.
Hit the "Power" button to turn on the computer. Press the F2 key on the keyboard. This must be done prior to the operating system loading; if the Windows OS logo has popped up, it is too late. Boot into Windows, restart the computer, and try again.
Pressing F2 on a Toshiba laptop takes you directly into the BIOS, and any settings can now be changed.
If you have successfully entered the BIOS Phoenix press F9 there will be an option that will pop out after pressing F9 the choose yes, after that press F10 there will be an option that says "Save and Quit." This will save any changes you've made, exit out of the BIOS, and restart the computer. Choose yes again, after that process the laptop will boot up now to your Windows Screen.
Try to use again the keys that are not working, if it's still not working definitely that's a hardware problem, you need to contact Toshiba Technical Support here's the phone number
800-247-7777
to assist you further with this problem or you can drop your laptop to a nearest Authorize Service Provider for Toshiba near in your place.
Hope this helps. :-)
Mar 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
My laptop has power but will not boot up. Just
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. if that doesn't work, you should try a Factory restore, Toshiba laptops from mid 2007 onwards dont have a recovery disc suppliedwith a purchase of a laptop. Instead, Toshiba has added a hidden partion on the hard drive which contains the same files on a recovery cd / dvd.
To reinstall your laptop to the factory settings / "out of the box" settings, please follow these steps. It worked for me, and should work for you.
ALL DATA WILL BE ERASED ON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THE POWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURING THIS PROCESS.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
This should get you back. If not, then you are going to need to get a Windows install DVD, boot of that and reinstall the whole system
Feb 17, 2010 | Toshiba Satellite 2455-S305 Notebook
EToshiba Satellite A100-S8111TD - Laptop do not finish boot on startup
Upon powering on, press the F8 button to load other options, choose safe mode only and hit enter.
If you were able boot windows under safe mode, you can try to do system restore or uninstall any program you've recently installed which cased the problem.
If you were NOT able to boot to safe mode, you need to do full system recovery and re install the OS. Insert the recovery disc and press F12 upon powering on to load boot menu then choose CD/DVD rom.
Hope this helps,
Sep 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
