Question about Bladez Exercise & Fitness
My switch light on my treadmill 6.9T-PR TURNS ON BUT THE LIGHTS ON THE DESPLAY CONSUL DOESN'T TURN ON? WHAT COULD BE THE POSSIBLE PROBLEM?
  • 48 Answers
SOURCE: My Healthrider R65 was in a flood. The treadmill
motor does not start as flood rusted contacts and brush commutators
open it and clean it
Posted on Nov 23, 2010
  • 11800 Answers
SOURCE: I have a Reebok 3500C
That key is the safety system of your treadmill - without it the motor (and only it) of the treadmill stops. The key itself is nothing more than a piece of plastic with a few very small magnets in it - it simply cannot go wrong.
The defect is in the console - the processor of the treadmill has failed. You will have to call a repairman to replace it.
Posted on Jun 14, 2011
  • 1196 Answers
SOURCE: when switching on my York
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Posted on Jul 17, 2011
ercupa190
  • 12223 Answers
SOURCE: When I cut the treadmill
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
Do this first. if the problem persist check the:
Reed switch +Optic sensor.
Posted on Nov 15, 2011
  • 22 Answers
SOURCE: I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Posted on Jun 02, 2012
Clubtrack 3.0 Plus. Why won't it turn on?
This sounds like a Faulty Motor control board.
Nov 01, 2015 | Exercise & Fitness
Dynamix treadmill instructions
you have a short circuit. Call to some electrician for to fix it the problem.
God bless you
Oct 16, 2013 | Exercise & Fitness
Reebok vista treadmill
This type of treadmills seem to have high probability of failure if you use the emergency cutoff switch instead of the power switch at the bottom.
My guess is by yanking the red magnetic safety switch, the induced current put a heavy load on the central controller circuitry, and over the time it damages the IC chips on that board.
There's a border-line failure phase before the controller goes completely dead, I realized this and stopped using the safety switch, it hasn't had any issue ever since.
Aug 06, 2013 | Reebok Vista Treadmill - RBTL13305
How to change from km to mph
from below display board, there are small orifice. Use pencil erase point. and clich the smal switch, and ready. However some models you must go to the Menu and make the set up for to change the speed kms vs mps.
God bless you
Jun 07, 2013 | Horizon treadmill Elite T3000
Brake light on 2000 ford windstar doesn't work
bad earth the wire that goes to the car body could be lose
Apr 16, 2013 | Ford Cars & Trucks
Hp laptop doesn't turn on, no lights
From the description it is a motherboard failure, only option is replacement.
Apr 30, 2012 | HP Pavilion dv1010us Notebook
Turn switch on and all the lights work but the starter wont engage
If the starter wont turn...Id check / replace starter solonoid.
If the starter turns but doesn't engage the flywheel...I'd check / replace the bendix.
If starter checks good and bendix is good...I'd look at the teeth on the flywheel.
Hope this helps...
Jul 23, 2011 | 2005 Jeep Wrangler
Power will not stay on
HI, make sure there isn't a short in the actual outlet wall socket. if the outlet wall socket is in good condition, this will confirm power board failuer.
You will need to replace the power supply board in this unit in this case.
Jun 13, 2009 | Reebok Vista Treadmill - RBTL13305
Exercise & Fitness Logo
Top Bladez Exercise & Fitness Experts
gbob59
ray gallant
Tom Chichester
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
