Question about Toshiba Satellite A75-S231 Notebook
Start menu & task bar do not appear
Start menu toolbar does not appear anywhere on the desktop once the desktop opens. however, the desktop icons do appear & the desktop icons open properly.
for: Toshiba Satellite A75-S231
Windows XP Home Edition
if i move the mouse pointer to the bottom of the screen... the start menu & task bar do not appear
  • Brett07
    Brett07 Jan 08, 2009
    dear FixYa friend,
    thank you for taking time to acknowledge my Toshiba Satellite dilemma support request. the laptop was having several malfunctions, more than just the one requested issue.
    ultimately i used the system recovery cd-rom to perform a full system recovery. my Toshiba Satellite laptop is new again.
    thank you again for your FixYa support & suggestions.
    Daryl
Why were start menu and task bar lost?
Hi B.G.R.,
Have you tried
Pressing ALT or F10 in your keyboard to make the Menu Bar temporarily visible. If you want it to be permanently visible, go into View > Toolbars > Menu Bar, or right-click the Navigation Toolbar (the Reload button, for example) and select Menu Bar.
If this doesn't help, right-click the navigation toolbar, select Customize... and click Restore Default Set. If it doesn't appear right away, try pressing ALT or F10. You can go into View > Toolbars > Menu Bar to make it permanently visible, or right-click the Navigation Toolbar and select Menu Bar.
Sep 12, 2015 | Computers & Internet
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
I did something and now i dont have a start menu
Click Ctrl+Alt+Delto get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hitthe Del key while holding them.Once the task manager opens Clcik the Processes tab then click the Image NameColumn heading on the left to get them in alphabetical order. Scroll downand look for explorer.exe. If you see it click it to highlight it thenclick End Process.
Next, click the FILE tab at the very top left of the window and select New Task(RUN). When the Create New Task window opens type explorer.exe and pressok. Your start menu, task bar and desktop icons will start appearing andpopulating. if not that means a virus has hidden your files and folders.
May 09, 2012 | E-Machines eMachines Desktop PC
Tool bar for computer gone how do i find tool bars in my computer
"FILE, EDIT or VIEW" options on the top.
  1. Open Internet Explorer, and make sure that it is running properly. If you receive any error messages upon opening it, your best bet is to reinstall Explorer rather than customize the options as new add-ons have likely caused serious problems. If it runs properly, however, continue to the next step.
  2. Check to see that the menu bar is visible. If the menu bar is missing, you will have to make it reappear. Right-click anywhere below the "Title Bar" (the bar which shows the Internet Explorer icon and the name of the current website) and any other visible menu bars. Then be sure that the "Menu Bar" has a check mark beside it on the window that appears. Click "Menu Bar" if there is no check.
  3. Click on "View" in the menu bar. Then click on "Toolbars" from that menu. This will bring up a list of available tool bars. To make the one you want appear, simply click its name, making sure that a check appears next to the name.
  4. Restart Internet Explorer. Some toolbars will reappear immediately. Others require a restart. But restart the application anyway to make sure that your new preferences are saved.
  5. Reinstall any extra toolbar applications if they do not appear in the Toolbar menu.
Please try this and see if anything help's.
Jun 15, 2010 | Microsoft Windows Vista Home Basic for PC
How to put program type on tool bar
  1. Adding Icons to the Task Bar
    1. Click on the Start Menu to open it
    2. Click on "Programs" and find the program for which you want to create an icon
    3. Move your mouse pointer to the program you want to use
    4. Depress and hold down the right mouse button while you drag the icon to the Quick Launch toolbar section of the Task Bar
    5. When you release the right mouse button, a short menu will appear
    6. Choose "Create Shortcut(s) Here." An icon will be created in the Quick Launch toolbar on the Taskbar
  2. Deleting Icons from the Task Bar
    1. Move the mouse pointer to the icon you want to delete
    2. Right-click on the icon
    3. Choose "Delete" from the short menu that appears. The icon has been deleted, but the program is still available to you on your hard disk
    NOTE: If you have carefully followed the steps above to add the icon to your Quick Launch toolbar, deleting it will NOT delete the program from your computer, it will simply remove the icon from your toolbar. The program will still be available to you.
Also you can "Drag" the program, to the bar, and "Drop" it on it. Check out a freeware application called StartupCPL at http://www.mlin.net/StartupCPL.shtml. This places a Startup icon in your Control Panel which, when opened, lists all applications on your PC with a check box for each one. Simply put a check mark in each application you want to open minimized on startup. By the way, it states it is for Windows ME and 2000, but I have had it on XP for quite a while and it works fine.
Mar 01, 2010 | HP Pavilion dv6000z Notebook
Can't see language bar
First try this: Right click your mouse while aiming it at the lower right of the task bar, but not inside the notification window (where the icons appear in the right of your task bar). You should see a menu titled Toolbars. Click on this and put a check mark next to the Language Bar heading. The language bar should pop up instantly next to the notification area.
If that doesn't work, do the following:
Open the Start menu, and go to control panel. If you haven't already selected it, choose use classis menu, then choose regional and language options and click on this to open.
You should now see a window that is titles REgional and Language options, and has a box at the top with Text services and input languages. Click on the Details button. This will open another window on your desktop, titled "Text Services and Input Languages" At the bottom of this window is a button titled "Language Bar". Click on this button to open the Language Bar Settings, and select your preference. It's possible you may have to reboot your system to get the language bar to update. If so, just trigger a restart when you go to shut down. The language bar will appear at the lower right of your task bar
Mar 26, 2009 | Microsoft Windows XP Home Edition
Start menu toolbar does not appear on desktop
Here's a couple of things to try:
Press Cntl+Esc key. That should bring up the Start Menu. Maybe the menu is hidden on one of the sides, or top. If it is, click it and drag it back to the bottom. if this doesn't work:
This problem can also occur when you are infected with a virus that seems to be unreported on symantec or any of the other anti-virus resources I've found.
If you can get to task manager go to the Processes tab, and look for a process called 'SYSU.EXE'. If it's running, kill it.
Now, if your desktop suddenly returns to normal, then yes, you've got this virus. You're not out of the woods yet. There is probably a folder on your machine called 'C:Program Filesddm'. Delete that, of course. You'll probably also want to search your registry for the string 'ddm' and kill most of what you find. In particular the key HKEY_LOCAL_MACHINE/SOFTWARE/ddm, and anything under HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion/Run and/or Run once that refers to 'ddm' or 'sysu.exe'.
As usual, I'll include that this entire procedure is something you should undergo with great care, or leave to a computer guru friend if you're not comfortable with it.
found this at:
http://forums.devshed.com/windows-help-34/no-start-menu-or-icons-on-desktop-winxp-66403.html
Jan 04, 2009 | Toshiba Satellite A215-S7422 Notebook
check this out maybe it can help..
in the desktop..put the cursor and right click-properties-select desktop-customize desktop-check the desktop icons you want..and click ok...just try maybe this is only you want..
Jan 04, 2009 | Toshiba Satellite A75-S213 Notebook
Start Task bar not showing
Press the Windows key to open the Start menu, then right-click the start button and choose properties.
Next, go to the task bar tab and
1. Uncheck auto-hide
2. Check keep task bar on top of other windows
Dec 11, 2008 | Computers & Internet
Toshiba Satellite A75-S231 Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
