Question about Whirlpool WED9371YW Duet Electric Dryer
My whirlpool duet sport dryer control panel will turn on but nothing happens after that. thecontrols change and everything but no drum rotation, no heat. and every once in a while I get the f-01 error code?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
You have a blown fuse if you remove the front lower cover you will see a white long fuse about 2 inch long it is bad after you put the new one on it will work but you need to keep the front off and turn on the dryer and look at the heater and see if it is lighting up red all over if not the heater needs to be replace it is shorted out and that is what made the fuse blow
Posted on Nov 02, 2012
  • 23 Answers
SOURCE: whirlpool duet ggw9250pl1
On Duet models, Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Posted on Jan 27, 2008
VOTIT
  • 2071 Answers
SOURCE: Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Posted on Aug 25, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
My dryer made a loud bang and wont spin
Bridgette, Most common problem is a broken belt when dryer drum dose not turn. Look through the attached links to help diagnose and repair your dryer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Drum Not Turning
Whirlpool Dryer Drum Not Turning
Appliance Repair Forums
Duet Dryer Drum Belt part 661570 How To Replace
Jul 17, 2016 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How do you clean out the baffles filled with lint in the Whirlpool Duet dryer?
To remove the dryer drum baffles on a Whirlpool Duet, follow these steps:
1. UNPLUG the dryer.
2. Remove the top panel of the appliance by removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. Locate the bolts that hold the baffles in place on the outside perimeter of the drum. There should be 2 for each one.
4. Remove the screws for the baffle and it will come off.
HELPFUL HINTS:
1. Remove ONE baffle at a time so you can use the remaining baffles to turn the drum manually.
2. Drum rotates in a clockwise direction.
3. When removing or reinstalling each baffle, duct taping it place will keep it from flipping around when you get to the last bolt holding it in place. It will also keep it from dropping in the drum when removing, and help you hold it in place to reinstalling.
If you have any questions, please let me know. I hope this helps you.
Feb 07, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
The dryer drum does not rotate. The dryer
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 16, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport Dryer drum will not turn
Most likely thermal fuse is bad, but also could be door switch or a control problem.
Oct 12, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Duet dryer drum does not turn.control panel turns on.
it appears the drum has come loose on my maytag dryer model #LDE313 but figure out how to get inside to checkout the drum
Feb 05, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool WED9371YW Duet Electric Dryer Logo
166 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
