Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Washer spins slowly - GE WSM2700W Unitized Spacemaker Washer and Dryer
  • donald bird Nov 06, 2012
    thank you for your response , Mr. Roth, I should have supplied more information. This machine has a coupling instead of a belt. After looking at the problem more closely, I believe it has a worn clutch. I will report back after take the machine apart.
  • Richard Roth
    Richard Roth Nov 06, 2012
    OK, what is that model number?
    Top Expert:
  • GE Master
  • 9,472 Answers
Remove the front panel and check to see if the belt is slipping.
Posted on Nov 02, 2012
    Its a GE stack washer/dryer model # GSM2700
    I made a mistake in my last post ,the model # is WSM2700
FRIGIDAIRE LTF2140FS1 SPIN SLOWLY
Hello friend, thanks for your post!
I understand that the spin feature on your Frigidaire washer is spinning slowly. It sounds like a potential problem with your motor control board or control board. I would recommend performing a reset and you can do that by disconnecting the power from your washer for roughly ten minutes. If that does not help correct the issue I would recommend having a professional come out. They will be able to pinpoint the cause of the issue and replace any electrical components to avoid any personal injury or future issues with your washer. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
The door is closed good. However, the washer will not spin.
if it spins slowly but atleast spins? You may have a slipping clutch, bad brake assembly or if belt driven a loose or worn belt. maybe even a worn down motor coupler
Sep 15, 2014 | LG WM1814CW Front Load Washer
Washer spins slowly and will not drain
Sounds like the motor might not be turning the tub at high enough RPMs
Aug 08, 2012 | Frigidaire FEX831CS Top Load Stacked...
Will not spin clothes dry,spin cycle not long enough
The clutch could be sliping which will cause the washer to spin slowly. This page will help http://www.appliance-repair-it.com/washer-not-spinning.html
Sep 21, 2010 | Estate TAWS800JQ Top Load Washer
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Washer spins slowly
your clutch pads are worn out they sell a kit to repair that
Feb 04, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will only spin with light loads. When
I replaced the clutch and the problem seems to be fixed
May 13, 2009 | Estate TAWS800JQ Top Load Washer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
48 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
