Question about Ovens
Need Parts for an American Crown gas cooking stove Model AR 404 B ?
I need the oven control and probe assembly...
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
VtToolMan
  • 704 Answers
SOURCE: I need to change my oven ignitor and I need a diagram
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Posted on Jul 31, 2009
EllaWatson25
  • 725 Answers
SOURCE: NEED PARTS FOR OLD WALL OVEN...AMERICAN CROWN
Please call me with your model number and I will do my best to find these parts for you. 9728590929. Thanks, Ella
Posted on Aug 22, 2009
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
SOURCE: I Lost the instructions for my GE profile Oven probe. Need advic
I need oven probe instruction and oven conversion time with the convection oven for cooking a forty pound turkey.
Posted on Nov 25, 2010
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
I walked by my stove and noticed heat coming from it and I opened the oven door and heat was coming from it. I did not turn on the stove top burners or the oven when I noticed it. The switch was OFF. I...
You most likely have a problem with the temprature contol knob and the thermostat.
This is all contained in one unit. The controller has a long metal "wire" that sends the temp info to the controller. The "wire" ends inside the oven.
This whole assemblage needs to be replaced.
I would need the type of stove, gas or electric age and model to give you replacement directions
Jul 01, 2011 | Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
We want to turn the oven off, it keeps saying chk probe
The stove is in probe mode for cooking.
This unit does not have a probe.
I suggest unplugging the stove for a few minutes (or turn off the breakers) to reset the controller.
If this does not cure it, you will need a service man.
Here is your owner's manual
Apr 04, 2010 | Jenn-Air JJW8527C Expressions Collection...
1937 anitque American Stove came with Magic chef cook book and Loraine thermostatic temperature regulator. Having problems getting Oven pilot light to light. Have checked thoroughly for leaks but have...
THE PILOT LIGHT IS IGNIGHTED BY AN ELECTRICAL WIRE THAT IS LOCATED BESIDE THE GAS JETS SO MAKE SURE THE ELECTRICAL IGNITION SYSTEM HAS POWER YOU NEED TO LOCATE THE WIRE AND FOLLOW IT TO FIND THE POWER SORCE THEN CONECT THE POWER SUPLY TO IT , GOOD COOKING.
Nov 22, 2009 | Ovens
Aug 19, 2009 | GE 30" Built-In Single Electric Wall Oven...
Stove shuts off and posts F10 on readout
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 30, 2009 | Whirlpool RBS245PDS Electric Single Oven
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
Ovens Logo
394 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
